Sewing Machines Logo
l
linda pollender Posted on Oct 17, 2018
I need to buy a LCD light for janome mc 8000 I live in Canada
sales402
Level 1:
Problem Solver:
  • Contributor 27 Answers
  • Posted on Jun 30, 2019
sales402
Contributor
Level 1:
Problem Solver:
Answers
27
Questions
0
Helped
6306
Points
35
Are you looking for the LED light or LCD unit backlight? If you are not sure you can contact us via email on [email protected]
5 Related Answers
Babal
  • Posted on Jan 10, 2008
SOURCE: Janome 8000 mc
Solution #1 worked for my Janome 8000 Thank You
Anonymous
  • 323 Answers
  • Posted on Oct 28, 2008
SOURCE: janome memory craft 8000
The screen is going bad and needs to be replaced. Unfortunately, it is obsolete.It is my understanding that a Janome Dealer can take your screen and send it to Janome to be rebuilt. It will take about a month. Be prepared to spend more than $200. The sewing light is the same one that is used in many Janome machines I.e. MC9000 and should be available from almost any competent sewing repair shop.
sewman7
Anonymous
  • 15 Answers
  • Posted on Apr 12, 2009
SOURCE: stepping motor error
From what I've read here, it could be one of two things: a blown motherboard or a scratched bobbin case.
Before you do anything else, I'd remove the bobbin case, clean it and the area around it thoroughly (and check it for scratches or dings -- perhaps a needle broke recently?) and then replace it and see if that fixes the error.
If not, unfortunately, I'll bet it's time for a check-up with a repairman. :(
Best of luck to you!!
bargainbox
Hassy
  • 1388 Answers
  • Posted on May 31, 2009
SOURCE: Janome Memory Craft 5700 LCD Screen
The LCD Backlight is prone to going dark eventually and fails progressively, but you can buy a replacement and even instal it yourself.....
We can now supply the LCD Backlight Screen for the Janome Memory Craft MC 8000 and Memory Craft MC 5700.
Keep your old Janome, save money and reduce unnecessary landfill.
It also comes with comprehensive installation instructions from the Original Janome Service Manual which are sent in advance so you can look at the "How to do it" before you decide whether you wish to DIY or enlist the services of a trusted friend or take the LCD Screen and installation instructions to your friendly local technician and have them do it for you.
Here is the LCD Backlight Link
Dulwich hill sewingcentre
  • 23 Answers
  • Posted on May 04, 2013
SOURCE: Touch Screen for Janome MC 8000 required
We have the Janome MC8000 touch screen avaliable please contact us from our website www.sewingmachine.com.au
1helpful
2answers
Memory craft 8000 how do you take it apart to replace light
When your Memory Craft 8000 or MC 5700 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the LCD screen, or buy a new machine.
Janome no longer stock this item direct, but there is an affordable replacement available.
Full Access and Installation instructions are provided, so you can DIY or have someone else do the replacement for you.
Check this Link
Also includes advice, links & contacts to be able to Reset your screen and do a Self Diagnosis Routine to test your machine BEFORE you purchase a replacement LCD backlight for either the Janome MC 8000 or MC 5700, so you can check that there are no other troubles.
1helpful
2answers
Screen dull on Janome mc 8000
There is an LCD Backlight Panel that illuminates the screen, and yes, they do fail.
Before you start, just check the screen contrast dial inside the top cover, front right, they can be easily knocked and this will also cause the screen to go light or dark.
Janome no longer supplies the LCD Backlight, however, we have an after market replacement at our store, and also provide fitting instructions and a good deal more besides.
If you care to contact me I can send a Diagnostic Routine and the Screen Reset instructions for you to check if there is anything else causing troubles.
Please remember to give details of your dilemma as we do receive a lot of requests.
Contact Link
Cheers
Martyn
2answers
Try this link for an affordable solution to repairing your Janome MC 8000 Display Back Light.
https://sew-bright.com/products/janome-memory-craft-8000-lcd-backlight-replacement-kit
How do i install my el board in my janome mc 8000 sewing machine
Try this link for an affordable solution to repairing your Janome MC 8000 Display Back Light Janome Memory Craft 8000 LCD Backlight Replacement Kit. The kit comes with a custom repair manual specifically written for back light replacement.
2answers
Janome 8000 LCD question
Try this link for an affordable solution to repairing your Janome MC 8000 Display Back.
1helpful
3answers
Need touchscreen backlight for merory craft 8000 janome new home
Check this Link
4helpful
3answers
The sewing advisor screen on a Janome 8000 is getting dim.
Check this Link
2helpful
3answers
Janome memory craft 8000
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
