To replace the two Circline Fluorescent bulbs in your torchiere floor lamp with LED bulbs, you will need to purchase LED bulbs that are compatible with the lamp's socket and have the same wattage as the original bulbs. Here are the steps to replace the bulbs:
- Unplug the lamp from the wall outlet to ensure that it is completely powered off.
- Remove the glass shade from the lamp by unscrewing it or lifting it off.
- Locate the two fluorescent bulbs in the lamp and unscrew them from their sockets.
- Insert the new LED bulbs into the sockets, making sure that they are securely in place.
- Replace the glass shade on the lamp and plug the lamp back into the wall outlet.
- Turn on the lamp and test the new LED bulbs to make sure that they are working properly.
- If you want to control the lamp with a smart outlet, you will need to install a smart switch or plug to control the outlet.
Note that it may be impossible to make the first click to not do anything, as it is part of the design of the lamp and how it was made to switch between the two bulbs.
