COMBI BINDER GBC 340 HANDLE JAMMED WHAT CAN I DO TO GET WORKING AGAIN? THANKS
1 Related Answer
Anonymous
  • 541 Answers
  • Posted on Oct 23, 2009
SOURCE: the machaine jammed and now will not work. i have
the machine still thinks it is jammed. the humming is probably the motor trying to turn, it can not beause it still has a jam? . you may need to remove the power cord from the wall. remove the shredder fro the stand. flip it over. remove the bottom cover and manual trun the cutting heads to unstick them. you may need a tech
1helpful
2answers
How do I fix a jam in my GBC Shredmaster SC70 Paper Shredder?
Run it backwards. Or you could put soapy water on the cardboard and paper to soften and lubricate it. Spray the cutters with WD40 afterwards.
It does have a manual reverse mode
https://www.shoplet.com/GBC-Model-SC70-Light-Duty-Strip-Cut-Paper-Shredder/GBC1757760/spdv
Correct replacement cutter head for series 3 340
braun series 3 combi 32S replacement foil and cutter blades pack silver color for electric shaver braun series 3 model 340 type 5775 parts.
Hi I have a GBC Shredder, made by swingline, model GLX2030. Since this morning the shredder didnt stop! Normally the shredder work only when we put paper into...but today we have to push the ''ON'' button...
There is an infeed sensor that isn't being made for auto on which is just a simple flipper switch and if it doesn't work it is because there is paper jamming it. Unplug it and turn it over where the blades are and see if clogged up and if so than put back on and reverse it and than forward again until it releases if it has a reverse ,reverse it. If no reverse unplug and use a narrow object to clear from the bottom side
1helpful
The machaine jammed and now will not work. i have taken it apart and removed all of the jammed material. when the machaine is turned on, it goes stright into paper jam mode. There is an electric humming...
7helpful
6answers
Ibico Binding Machine User Manual/Instructions
I found the IbiMaster 400 manual!!! The key was finding out that Ibico was sold to General Binding Corp. (GBC). I went to the GBC web site and it linked me to Acco. I called Acco and they promptly sent me an old, scanned PDF of the manual. The very helpful POC at Acco was:
[email protected]
Jerry Quinn
3answers
GBC Quartet Shredder - Service manual
try this customer service number for help 800-541-0094. I believe that Acco is the parent company for GBC.
Top Gbc Office Equipment & Supplies Experts
ADMIN Andrew
ADMIN Andrew
bvmihai
Ngoro
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
