WHAT SHOULD I DO ABOUT THIS PROBLEM WHEN I SWICH ON THE POWER IT WILL OPEN A MINUTE ONLY AND SUDDENLY BACK TO OFF TO STAND BY MODE
SOURCE: Sony HCD-BC150 As soon as I turn it on, it shuts
Change the audio amplifier IC are on short circuit and that´s the cause your device goes to protect mode
Testimonial: "Tell me how to download a sony hcd-bc150 service manual! Your answer was brilliant!"
SOURCE: Power/Standby mode blinking, what is the reason?
I have a Denon AVR1708 and a Denon AVR687. Both had this issue and the issue is related to high temperature usage; like if the unit is in an entertainment systems with poor ventilation. I was able to fix both fairly easily. The issue is related to the voltage regulators on the power supply board on the 1708 and the main board on the 687. In my case, I had failures of the -15 volt regulator KIA7915PI. Both I believe were related to high temperatures.
You can get the regulator for as little as 50 cents at some online stores. The job on the 1708 was easy, however, on the 687 it was a bear. It took about 1/2 hour on the 1708 and 2 to 2 1/2 hours on the 687. The component is a lot harder to get to on the 687. The component needs to be unsoldered and removed and the new component soldered in. You will probably have to remove some caps to get go access. Thermal grease should also be applied to the new component.
Hi, this is an issue with a sensor on the power module. To fix it you must replace that part.
SOURCE: Sony Bravia stuck in stand by mode
What is wrong when it is in Stand by mode blinking red light 4 times, then pause, then 4 times....
