Check the book, i think the LOC code stands for Loss of Coolant or low pressure coolant.... Somthin like dat
It depends on if its over voltage or undervoltage. I would check the governor linkage and throttle settings while using a volt meter and a 100W incandescent bulb.
SOURCE: honda petrol em70 ..is... generator what type oil is required for this generator please
You can use Engine Oil of API - SF grade 20W40 & 15W40.
Any engine that burns oil should be given a compression check and then have the compression rings replaced if they leak.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_e0539de310ea5ad7
