I took a couple of bolts off back of washer. Found out how unassemblr to replace lid switch. after reassembly, the spin cycle shakes with small load.
Syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
I have a Kenmore 22990 top loading washer. it shakes violently and walks across the floor during the spin cycle. it started doing it about two weeks ago. moving clothes around inside the tub does not help much.
kenmore washer shaking while spinning
roper washer w10420470a lid lock light is off during spin cycle
door seal is damaged causing the machine to shake when spinning
we can do very small loads but a normal load will not complete the cycle. With about 6 minutes left in the cycle it starts shaking violently and stops with the code ul
The washer bounces and moves during the spin cycle
spin cycle is load and shakes, top part of agitator seems loose
replace damper pads
what tools are needed to to do the job
shaking violently
