SOURCE: I've replaced the computer on
If you don't have the owner's manual you can download it here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%204452300.pdf
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20(Micro)%20-%204452614.pdf
Some units will not allow time programming if the door is open - or if the microwave thinks it is due to a bad door switch or door switch mount, etc.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
SOURCE: GE Microwave won't heat or cook - one year old
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
SOURCE: Problem with the GE Advantium
sounds like the magnetron. Youll have to have a technician replace it. if you have a warranty just call the company and they should take care of you.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
