Nautica watch
SOURCE: Leather wrist strap
I would scrap the strap - the odours are caused by the tanning chemicals getting wet. Retain the fastening and purchase half a meter of nylon ribbon loop it through the case pegs on one side glue them together and pierce for buckle holes. On the buckle side loop it through both case peg and buckle and fold and glue. You have a choice of colour and it cost only fraction of a new leather one- also you will have enough left to make two straps
SOURCE: Adjusting the strap
Most clasps have a series of small holes drilled in them, and the end of the strap is held in by a small, spring-loaded bar whose ends are seated in one set of holes. Take the end of a small paperclip, or a large needle, and use it to depress the spring-loaded pin. You can then carefully slide it to another set of holes to make the band smaller. Don't let the ends of the pin slide all the way out of the clasp, or it might shoot off into space.
SOURCE: Looking for G-Shock 2600 watch strap replacement
Visit www.casio.com/ - 8k - Cached - Similar pages
If you can not find anything there, find your nearest watchmaker and ask for help.
SOURCE: Where can I buy a new White Resin Nautica watch band.
If you go to the web site www.nauticawatches.com and select "service center" you will be able to see all the service centers. Choose your nearest and ask them.
Testimonial: "THANK YOU"
