SOURCE: Avanti EWC28 Wine Cooler TOO Cool
contact avanti cust svc they are easy to work with and want you happy tell them your promb but i suspect you need a new themostat
SOURCE: my cooler cannot cool
pull it out and lay hands on the compressor and see if its running if not replace the thermostat
SOURCE: Avanti wine cooler temperature problem
repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area location.
SOURCE: Avanti 12 bottle wine cooler...switch
CHANGE THE CAPACITORS ON THE POWER SUPPLY (TO SAME VALUES) AND REMOVE THE JUMPER (CATODE OF THE BRIDGE TO THE CAPACITOR DOUBLE VOLTAGE)
SOURCE: 2 mos old. simply stopped working. no power at all to lights, motor ,etc.
check if you get power by the motor if no power change the thermostat
Did you ever fix it? If not, I need a new control panel/front display and since parts are discontinued I need from an existing unit.
