SOURCE: wiring diagram for ford 9n tractor
You can purchase a manuel for your tractor at Tractor Supply or at tractorsupply.com for about $25-$30.
SOURCE: install distributor points on ford 9n process needed
try this site... http://www.ytmag.com/atrp/specs/ford.htm
SOURCE: 1950 8N FORD TRACTOR WON"T START.
Hi..my name is Keith..and i have 9 ford tractors..i have 9N's..2N's and 8N's..and i have converted one or two of them over to 12V..and i use the solonid that has only 1 side post...and thats what my original starter swich connects to and on the big terminal i have the battery wire and a 12 gauge wire that i run to the amp meter....i hope this helps..and if you have any questions..please write back
SOURCE: My 9N Ford Tractor won't start with a new 6volt battery.
No water in the distributor or wires ... right? Spray with a popular water inhibitor and/or dry with a rag and or air pressure.
