The output stage of the amplifier ( often its a STK powerpack or vintage builded bij individual transistors or fets) its on the cooling blok ,and sometimes a fuse resistor(s) caused by bad capacitors,
or worn solderings on active components.
some cause for cable damage (short circuit) or terminal volume or impedance.
SOURCE: connecting jvc shelf stereo model # ca-hxd7 to a television and karaoke machine
I'm sorry, but you won't be able to that.
SOURCE: Video & audio interruption
damaged power supply board or damed vga board could be capacitors or other issues need a service tech to look inside and see what gong on.
SOURCE: Front Audio Video inputs not working
What model TV is it?
it may be you need to change the input to video 1 or video 2 to get those front jacks to work. if there is a TV/Video button on the front you should be set. If not you may need the remote control. Sometimes changing the channel to below channel 1 will give you that option.
SOURCE: sound low, can barely hear the singer
either you have been downloading **** limewire songs or your headphones are screwed up.
