I have this above listed laptop, and windows tries to repair but to no avail. I have inserted bootable discs and I heard the dvd drive make a sound or two, but the laptop informs me there is no bootable disc in the drive. Which i know to be incorrect. Please help
Relic PCs with CDrom and no DVD drive ! 15 years old today, Id trash it and upgrade. Buy loptop 2010 or newer, and WIN! well we test the hDD first. installing any OS made is going to fail if the HDD is bad. we test the hdd, in all cases, or a full day can be wasted doing the impossible. thick of HDD as bucket. some are good, some are dead.(missing ) or some leak. like bucket with rust holes in the bottom, see? test 1 is does the hdd spin, heard? test 2, does the HDD show up in your BIOS. if not, it is dead. test 3, if above ok we run linux boot media,in demo mode. and then run the DISKTEST. with no DVD drive, you need to use old linux, boot CD. if the PC was upgraded to DVD use the DVD boot. http://www.pcdied.com/linux.html#Noobs
SOURCE: ACER ASPIRE 3680 WINDOWS ERROR RECOVERY
hi
you said u did try to press F2 or F8 to get to bios setting, are you saying pressing these would not open bios setting windows?
shakeel
SOURCE: toshiba dvd rom sd r6012 isn't reading the DVDs
Try some factory CD and DVDs and just try to get them to open in Windows (not play in a media player program). If you get errors on every disc you try, it may be your CD/DVD hardware packing in.
If it reads some CDs or DVDs and not others, particularly media discs, you may be having software driver problems, otherwise, it is likely hardware.
Try inserting the disc and spinning it up while resting the laptop on its side, or even upside down. If it reads sideways or upside down, the CD/DVD reader hardware has gone and cannot probably be prepared (this is a symptom of physical controller failure and is ot fixable by normal means).
Good luck...
SOURCE: Vostro laptop dvd/cd player not seen by system.
1.go to bios by pressing f2 key on dell logo
set num lock caps lock scroll lock on
press alt + e
press alt + f
press esc twice
2.
Step 1: Start Registry Editor
loadTOCNode(3, 'resolution');
Click Start, click Run, type regedit, and then click OK. Registry Editor starts.
Step 2: Delete the UpperFilters registry entry
1.
In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
2.
Expand SYSTEM, and then expand CurrentControlSet.
3.
Expand Control, and then expand Class.
4.
Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
5.
In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak.
6.
On the Edit menu, click Delete.
7.
When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:
Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry
1.
2.
3.
4.
5.
In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak.
6.
7.
When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:
Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
8.
Exit Registry Editor.
Step 4: Restart the computer
SOURCE: IBM Thinkpad R51-Recovery Disc
I have an r-51. are you completely relying on the recovery disks or do you have a copy of windows with a valid key
