SOURCE: penn fishing reels
For a Penn GTO 220, pls check this page an exploded view of the GTO220 that details parts and their placement. It is a PDF file and would need Abobe Acrobat Reader to view and print.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
SOURCE: SHIMANO FISHING REEL
The drag is set by turning the knob which secures the spool to the reel.
To cast, hold the line against the rod with index finger on right hand. Then flip the bail open which frees the line to come off the spool. The bail, when it gets to a certain point will lock open. When casting, release your finger on the line when the rod gets to 11 o'clock.
Flip the bail back by turning the reel handle -- the bail will pop back over the reel -- then you're ready to reel it in.
The bail is the wire-like device on the top of the reel.
There is probably a button/switch for turning anti-reverse on & off -- when on, this keeps the reel from turning backwards when force is applied to the line.
I think those are the highlights.
Charlie
SOURCE: Need to get a English manual for Shimano Denduo
http://fish.shimano.com/publish/content/global_fish/en/us/index/customer_service0/instruction_manuals.html
Get's you the current manuals in english.
SOURCE: Could some one please send an instruction manual
log onto shimano.com and there you will find manuals for everything they produce, failing that request it from customer support, they are very friendly to deal with
