Question about Kohler Electrical Supplies
My Kohler generator set tripps in 2 minutes once load is applied on it. The model is 250REOZDD. What could be the problem.
    Novelist:
    Habit-Forming:
  • 118 Answers
    Top Expert:
  • Kohler Master
  • 23,169 Answers
Maybe you are drawing more amps then it has???
Posted on Oct 14, 2018
Testimonial: "On not at all. It trip with a load of 112 Amps and the unit is 300KVA, 240kW."
4 Suggested Answers
SOURCE:
  • 230 Answers
SOURCE: hot tubs
Check the connections and the pump motor. There is a good chance the pump motor has pooped out
Posted on Sep 08, 2012
  • 512 Answers
SOURCE: What is the most likely cause of an Auxiliary Fault on a Kohler Generator (Model 30RZ62)?
Problem solved by poster. good work!
Posted on Oct 08, 2012
ineedabin50249
  • 755 Answers
SOURCE: Will generator be damaged by Microwave lugging down the generator?
nothing will happen to the gen but the microwave will stop working because of the resinator in it not putting enough power to it
Posted on Jan 20, 2015
I have a Kohler 7.3 ECD generator with error code UVunder frequency. Restarted gen and it ran for one hour so I shut it off. What's the problem?
check the operating rpms
the rpms determine the voltage and frequency and can be adjusted at the governor spring setting
adjust it until the voltmeter reads the required voltage
set slightly above to allow for rpms drop under load
for example if 240 volts set around 250 volts and that will drop back to 240 volts under load
if 110 set around 115 and that will drop back under full load
both frequency and volts are dependant on rpms
Sep 20, 2016 | Kohler Electrical Supplies
When I plug in a tool, it runs fine, when I plug it into my house with the breakers all off, it blows the breakers on the generator? My Honda 2200 watt works fine this way?
I think there is overload .kindly measure ur load of consumption. Do not run the generator set with high load it can be cause of circuit breaker Tripp off .
Oct 27, 2015 | Honda Electrical Supplies
Kohler 40EFOZD Auxiliary Lamp starts flashing After 2 minutes.
Make sure you have rated speed and voltage on the out put side.
Oct 13, 2014 | Kohler Electrical Supplies
Surging
It definately sounds like a fuel problem, lack of fuel..I assume it is running on LP or natural gas. The hose running from the demand regulator goes to the carburetor/mixer. When it gets to the carburetor, there is an adjustable main jet. It is different on different models, but is usually easy to find. There is probably a screw slot in the end of the screw head and a spring under the head. Start it up after locating the screw and open the jet just enough to even out the running. It was factory set, but barometric pressure and altitude and different fuels in different areas will decessitate different settings.
Please let me know if this fixes your problem, Robert
Jun 27, 2013 | Kohler 30RESA 30kW Standby Generator...
I have a Kohler 12 RES home standby generator. Once in a while when the power goes out the generator will start and then immediately shut down with no fault codes. When I flip the control in the unit
Check the inlet fuel pressure, on exervise there is no load, when power is out it is loaded and demands more fuel. Also check for bugs blocking gas regulators vents etc
Nov 12, 2012 | Kohler Generator. 12 kW and 14 kW Home...
Kohler marine generator troubleshooting
I have a kohler marine generator that shuts down when it reaches operating temp of 200/210 degrees. It runs for about 5 minutes. Already replaced impella and have sea water pumping through, coolant level is good. Any suggestions? Thanks
May 02, 2012 | Electrical Supplies
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
Kohler magnum12 gas generator will not produce electric power
Plug an electric drill into your output power at the generator IF you have a plug at the generator. (Output power CB must be on.) IF not the closest point to the generator and then pull the drill switch and turn the drill in the reverse direction. That will flash the field. 1/2 inch drrill works best but with some effort a heavy duty 3/8 drill will work. Just rotate it quickly... when the generator starts working it will try to yank the drill from your grip so keep that in mind. (Trigger Sw on drill ON)
Kelly
Sep 02, 2009 | Kohler 12 kW Emergency Power System -...
My Kohler 17RES has stopped doing it's scheduled weekly exercise. How can I get it exercising again?
On your Automatic Transfer Switch ( the little gray box you see on the right in the picture above) you have two blue buttons. One is a Manual test switch. The other has a clock on it and this is your exercise set button. Hold it down for a FULL 3 seconds if you want it to excercise without a load (not powering your home) Hold it down for a FULL 6 seconds if you want it to exercise with a load every week. Your generator will start and run for 20 minutes, and then shut down. Now every week your generator will exercise at the time and day that you pushed the set button.
Aug 08, 2009 | Kohler 12 kW Emergency Power System -...
Electrical Supplies Logo
169 people viewed this question
Top Kohler Electrical Supplies Experts
Sheldon Dedek
rjivaro
J. Bradshaw
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
