Lands Phones Logo
A
Anonymous Posted on Oct 14, 2018
Vtech cordless phone. When I call out or receive a call the person on the other line cannot hear me but I can hear them clearly. What to do to fix the problem?
T Tatro
Level 1:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 20 Answers
  • Posted on Jun 19, 2019
T Tatro
Contributor
Level 1:
Greenhorn:
Cheetah:
Answers
20
Questions
0
Helped
4566
Points
38
1. In settings try to turn up the volume.
2. Using a Q tip and some alcohol make sure the mouth speaker is clear.
3. Check with Telco to make sure the telephone line itself is working properly.
5 Related Answers
Anonymous
  • Posted on Dec 20, 2008
SOURCE: vtech cordless phone/ detc 6.0
This worked for me. Unplug the power to the base for 10 seconds then plug the power back in. That did it for my "connecting....." problem. Good luck!
Anonymous
  • Posted on Jan 12, 2009
SOURCE: vtech cordless phone appears to be mute
does anyone out there have a solution for peggy's problem? I have the same problem------Bob
Anonymous
  • 95 Answers
  • Posted on Mar 28, 2009
SOURCE: My vetech cordless phone is not working
DO you have a 2 line model? If so check and make sure the conf (conference) button is not pushed as it will keep the line off-hook forever. Hope this helps!
nature_lady1
  • Posted on Dec 18, 2009
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
Anonymous
  • Posted on May 19, 2010
SOURCE: 5.8GHz Cordless Phone with Digital Answering System & 4 Handsets: my vtech cordless phone says connecting and i can'...
my vt phone is lock and need to unlock it help
Vtech cordless landline phone When I make a call to someone the other person can't hear me but I can hear them? Please help me in how to fix. Thank you
Google
make model manual
you have 'Mute' set on it.
All questions need 'make model (what it is)' as first 3 words.
1helpful
Unplug the battery from the phone (handset) for 1 minute and also do the same for the base simultaneously, replug them and repair the to each other if you have to and then give it a try, also try and clean out the mic holes eat the bottom of the phone and make sure its not on must , do not disturb, or any other feature enabled that a would cause you to have such undesired function. I hope this help and for expert help you can find it here https://www.6ya.com/mr.mike and if you need more help you can always ask another question
3helpful
My vtech phones show NO LINE; MY OTHER PHONE WORKS
More than likely the phones base station (transmitter) is defective, this is a common failure on Vtech cordless phones, i have owned two and both failed the for the same reason. I also see this problem posted often for Vtech phones.
Our line one cuts out even when we're talking on it & we can just barely hear the person on the line but they can hear us clearly. We have unplugged the phone's power cord & plugged it back in...
I have the same sort of problem...kinda..lol. My Vtech sorta 'cuts out' when there is noise at my hosue. The person I'm talking to can still hear me but I can't hear them. If my son starts crying or there's any other loudish type noises on my end, it's like the phone is trying to cutout my background noise, but all it's cutting out is the person talking to me. It's not that the noises in my house are loud and I jsut can't hear the person I"m talking to, b/c if i cover the mouth peice then no matter how loud the sound in my house is i can still hear the person i'm talking to but I HAVE to keep the mouth peice covered. It's really annoying!
6.0 vtech phone , I must raise my voice for
Try turning your volume up on your phone while you are talking. Is this a perticular person? or is it for everyone?
5helpful
Can't be heard
Sounds like you have a defective microphone in your handset. Maybe caused by dropping of phone or water damage. Try land line phone not cordless. Just to ensure that you can hear the caller and can be heard over your phone line.
If you can complete a call successfully go and purchase another cordless phone.
Phone base set 'in use' led flashes when plugged into the jack
As is usually the case, a very simple solution in the end. Always check every thing even if the info supplied is from a qualified person. The phone came with the wall jack to base cord but it wasn't the origonal one so the phone thought the line was busy because it wasn't receiving any voltage supply as the plug into the base set had transposed 1 with 2 & 3 with 4. Damn I hate it when its that easy. I was talking to another mate about it and he said he had a similar fault to mine & he thought the cord was the issue & he was correct.
Thanks for your time
Brent.
1helpful
Working one set of Vtech 6041 cordless phone set with another?
I have the vtech dect6.0 with one answering system and two remote docking systems.I can phone out from the remotes but cannot receive incoming calls from the remote.When I pick up the remote to receive the phone immediately shuts off.
1helpful
Vtech 9127, display bad
my vtech 5.8 GHz disconnects while I am talking~replaced batteries and charges the phones for 24 hours. I cold talk 10 minutes during this time 4x I could hear the other person~they could not hear me and then disconnect.
Characters and numbers are choppy too Thank you
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
