Televison & Video Logo
S
Sandra munoz Posted on Oct 13, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to reset hitachi 51f59a
Don't have remote hit wrong button can't change input
Chris Harding
Level 2:
Habit-Forming:
New Friend:
  • Expert 30 Answers
  • Posted on Oct 16, 2018
Chris Harding
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
30
Questions
0
Helped
26460
Points
112
You can change input using inputs button on remote or the TV button to bring it back to the correct live TV source. Here is your manual: Hitachi 51F59 Operating Manual
5 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Jun 08, 2008
SOURCE: Hitachi 51F59a audio problem
most likely its a solder issue on the audio output IC. if it has external out put connections check those for solder cracks as well as that can cause audio to drop out also
Anonymous
  • 51 Answers
  • Posted on Aug 06, 2008
SOURCE: TV input
it is likely that your tv is interpreting a random button on your remote as a signal sent for it to change inputs, next time this happens turn the tv off and back on and note what comes up on the screen, for example video 1,
Anonymous
  • Posted on Nov 14, 2008
SOURCE: Can't change channels
I had exactly the same problem. I finally found the power button on the underside of the TV. It is well hidden and to find it, you need to run your fingers underneath the panel. Turn it off for a minute or so and turn it back on and then turn on the switch on the panel on the upper right side where the channel and volume buttons are. It works.
Larry
  • 14 Answers
  • Posted on Aug 13, 2010
SOURCE: When I push the device button on the remote, I
I had this same exact problem with my WD-62627. I got mine to work by re-initialing the tv. I could not believe this worked. Try this, 1) turn on the TV
2) press MENU 2,4,7,0 then ENTER
3) the TV should INITIALIZE
4) Press the front reset button on the front of the TV.
5) should work again....if so.....
6) email me at [email protected] to thank me. :)
Anonymous
  • 5 Answers
  • Posted on Aug 18, 2010
SOURCE: Hitachi 32LD6600 defaulting to ext-5
easy
you have to get your tv into "hotell" mode:
1 meny then type 1,3,2,5 and the hotel meny show...set it on and to start on ext5....close with meny...turn tv off and then on and your problem is solved
Change input on Hitachi LCD TV model LE65K6R9 without remote?
I'd unplug/disconnect the Roku and after 30 seconds try the control button on the back. If you can change the input do so, then plug the Roku back in. Until you use the input button on the back to change input to Roku, you should be able to use the other buttons on the back to control the TV. If this does not work, unplug both the TV and the Roku. Wait maybe a minute, then plug the TV back in and follow the above instructions. Here are other alternatives: Using physical buttons: You can find the physical buttons on the left or right back side of the Hitachi TV. Using these keys, you can change the input, adjust the volume, or turn on Hitachi TV without a remote. Press the Input button located at the back or side of the Hitachi TV. The list of connected sources will appear on the TV screen12.
Using external devices: Connect a wireless keyboard or mouse to your Hitachi TV and change the input1.
Buy a universal remote: You can buy a universal remote to control your Hitachi TV and change the source.
How to work the hdmi
how do you set up the HDMI input on a hitachi tv model #51F59A ...
https://answers.yahoo.com/question/index?qid...
Jan 8, 2010 - i tried to hook up an HDMI devise but i cant set it on input HDMI it ... My TV has HDMI, Component and AV inputs, which one should i use for my ...
HDMI not working - Hitachi 50VS69A - AVS Forum ' Home Theater ...
www.avsforum.com/.../948284-hdmi-not-working-hitachi-50vs69a.html
Dec 1, 2007 - 7 posts - ‎2 authors
I have a Hitachi 50VS69A 50 RP LCD HDTV connected to a Dish Network receiver that the HDMI input is not working on. I have been using the ... Hitachi P50H401 - all HDMI ports are dead - HELP!
Oct 2, 2008
Hitachi 51/57/65F59A CRT RPTV Tweaks Thread
Jan 19, 2007
More results from www.avsforum.com
I pressed the buttons on the side of the tv and now i cannot get a picture
It's probably the input. Use the input or source button to change the input to the one corresponding to your receiver (don't know? check the back of your DISH remote or try them all!) Most TVs will change the input to the old TV (ch 3, etc) when you hit the channel up or down button or if you hit input or source, so it only takes a small brush with the wrong button to ruin your night.
51f59a hdmi how do I make the tv see the hdmi port? I don't have the remote or lock code
you can use the buttons on the TV to select the input no lock code should be necessary
Changing inputs on hitachi tv 46w500 with out a remote
The Hitachi 46W500 has an Input button on the front of the TV. (This is the second button from the right. The right-most button is the Menu Button.) You should be able to press this repeatedly to switch between inputs.
If the Front Panel Lock is engaged, you need a remote to unlock this. (Only the Power button works when the FPL is engaged.) A universal remote which has a code that matches that needed to get the Menu button to work will do the job.
I hope this helps.
My hitachi 51f59a has no picture or sound but the menu will come up
1. I would first check to see which input you are actually connected to and if possible try another.
2. If the Menu comes up use the input button to make sure you are on the one you are connected to.
3. Lastly, try hooking something to an unused input and see if it works and if so check whatever you are using for signal for regular Tv.
The more you tell me the better I can help.
1helpful
Where's the bulb located on hitachi 51F59A?
Hitachi 51F59 Manual
OR CONTACT HITACHI AT
800-448-2244
Press 2 then 1 then 3
Average Wait: 14 mins - 24 hours, 7 days
2answers
We have a Hitachi 51F59A which has stopped producing a sound output. We have had this rear projection television for 18 months. What part is needed, and is it covered under Hitachi warranty?
would you like to sale it. you can call at 419)741-7350
I am looking for a 51 inch high definition hitachi television model no:51F59A.
Wanted A Hitachi 51in for Parts
1helpful
Model 51f59a hd widescreen aspect settings dont take and picture too big
I called Hitachi and the solution is in your cable remote not your tv remote. Your tv has a aspect menu as does your cable remote. Based on your cable provider you should have a settings or menu button to change the zoom or aspect of your screen. I had the same problem and have Comcast as cable and this worked for me.
2answers
Hitachi 60V500A Tv changes inputs by itself
sounds like the tac switches on the actual tv which are very hard to get they may be sticking
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
