Question about Pramac Electrical Supplies
Pramac electric start generator. Where is the choke, gas cut off, what is on/off switch in upper right of panel for?
SOURCE:
  • 226 Answers
SOURCE: 1984 aspencade starts w/choke and revs up, runs smooth. Take off
My 'wing won't run unless it has been warmed up some. I would suggest that you r&r your carbs to make sure the jets in the bottom are working correctly. They tend to get plugged up, especially after sitting & the aluminum flaking off inside... Rick
Posted on Apr 14, 2009
bbreton
  • 437 Answers
SOURCE: mb 3200 gas leaf blower will start when choke
The carburetor could need rebuilding or you have some bad gas. I would mix up some 2 cycle oil and fresh gas from the station. I would try the new fuel mixture first.
Good Day.
Posted on Nov 02, 2009
  • 11 Answers
SOURCE: Trimmer will only run in choke position
You have a few possibilities. Make sure you have good fresh gas in the tank. You're not getting enough gas, so choking helps get more gas than air, making it run better. Could be the carb diaphram (not very expensive if you replace yourself), when they get old they don't perform like they should. Could be the filter in the gas tank is bad, plugged. Also might be just an easy adjustment on the carb Low, and High speed screws. The choke has three positions, full choke, partial choke, and no choke, which means run position.
Posted on May 05, 2010
kel1guy2002
  • 3740 Answers
SOURCE: perkins 3 cylinder powered pramac generator
Start looking at your safety circuits.
1. High water temp
2. Low Oil
3. Low water etc...
From the manual these are the protection circuits.
• Engine protection: low oil pressure, high engine temperature.
• Genset protection: under/over voltage, overload, battery charger failure, battery voltage out of limits,
under/over frequency, start failure.
• Circuit breaker protection: IV poles.
• Differential protection.
Any one of them will trip the fuel relay closed. What you may be able to do is disconnect one at a time each protection circuit and see when the fuel relay opens. (Make sure to reconnect each one if it had no effect on the fuel solenoid)
Once you isolate which circuit it is in then you can chase wires or change the bad switch.
Thanks for choosing FixYa.
Kelly
Posted on Jun 26, 2010
GeneratorDan
  • 44 Answers
SOURCE: how to start a gas generator (should the choke be
Most Generac generators have a lever for the choke that pulls out. So if the generator is being started for the first use or cold you should choke when starting . Let it run for 30-45 sec. then push it in . Once the engine has been run or warm you dont need to choke every time when starting .
Posted on Nov 05, 2010
Trying to start for the first time it cranks but will not fire up. I have fresh oil fresh gas and have gas valve open. I tied opening the choke and closing and no success. Am I missing something?
Remove the spark plug and see if it is wet. If it is, you have gas in the combustion chamber. Check the gap.
Does it have a kill switch? Is it electric start?
The choke needs to be in operation until the generator is warm.
Feb 06, 2016 | Electrical Supplies
Champion 3500 generator how to fix stuck float
It could be a carburetor problem or it may be the low oil cut off switch. Check to make sure oil level is up. If it is check the needle valve attached to the float and the seat. The old carbs used to have a brass seat. Some of the new carbs have a rubber seat and it may need to be replaced. Hope this helps.
Dec 31, 2013 | Champion 3500/4000 Watt Portable Generator
Pramac 25 kva perkins encl diesel genset will not start red light on triangle on check list
Hello. Maybe you have solved your problems. But I still want to share the helpful article to you. https://www.dieselgeneratortech.com/diesel-generators/why-diesel-generator-fail-to-start.html
We are Perkins diesel generator OEM. Can provide 22KW to 2200KW diesel generator set with Perkins engine. https://www.dieselgeneratortech.com/perkins
Dec 09, 2013 | Pramac GBW30P Encl Diesel Genset w/Perkins...
I have a clark g900/700w generator.i started up today.started ok but when i turned the choke off it started to cut out.it will only run on half choke thanks
Is the gas fresh?
Possibly stale gas is the problem
http://www.clarkeservice.co.uk/manuals/generators/g900.pdf
Has engine been serviced: clean air filter, fuel filter, spark plug.
Clean out fuel system with carburetor cleaner. Place about 12 oz. in fuel tank and run engine.
Oct 29, 2013 | Clark Electrical Supplies
Perkins 20 kva diesel generator runs and stops in about 2 minutes.alternator failure is displayed on screen.
Ensure any engine control switch is set to the run position, with the load disengaged. Manually set the air shut off valve (if fitted) to the run position (see Fig. 18), Turn the key switch to the start position, which will energize the solenoid allowing the engine to crank over for a few seconds then start.
Check the instrument panel is showing normal running oil pressure, and the ammeter for charge to the engine batteries.
Allow the engine to run for five minutes checking the instruments are reading correctly. Stop the engine and check the oil and coolant levels, replenish if necessary.
https://www.dieselgeneratortech.com/generator-sets/normal-starting-procedure-of-Perkins-generator-set.html
Sep 28, 2013 | Pramac GBW30P Encl Diesel Genset w/Perkins...
ELECTRICITY PRESENTS BUT GENERATOR START IN AUTO MODE
You have the remote control wires incorrectly connected either at the ATS or on the generator control panel, disconenct from both ends and ohm them to make sure they are not shorted between. Then reconnect them at the generator end only. Then join them together manually, of the gen starts and stops when taken apart, the problem is in the transer switch, or incorrect terminated
Jun 14, 2013 | Pramac GBW30P Encl Diesel Genset w/Perkins...
My generator wont start
Fresh Gas? Gas line on? Run/stop switch on Run? Plug wire connected?
Aug 30, 2012 | Pramac 3000 Watt Gas Generator
Electrical Supplies Logo
80 people viewed this question
Top Pramac Electrical Supplies Experts
Marvin
Marvin
Lawrence Oravetz
wadingriver
wadingriver
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
