Question about Amana Washing Machines
My Amana LWA50AW/PLWA50AW is agitating very slowly. I changed the belt, which was badly cracked all around with a few pieces missing. It still is agitating very slow. Everything else seems to be working properly. What could be the issue? Thanks.
    Dedicated:
    Visited the website for 20 consecutive days.
  • 439 Answers
A similar inquiry has been previously posted, Hopefully one of the responses will relate directly to your low agitator speed problem -
Amana washer LWA50AW
Posted on Oct 13, 2018
  • 5 more comments
  • Sharon Devan
    Sharon Devan Oct 14, 2018
    It seems like the belt is too big. The tensioner arm is moving freely, and the spring pulls it as tight as it can go. The bolt/rod that moves when the tensioner arm moves is also moving freely. No pulleys are cracked or broken. I set the machine and turned it on, and watched the belt/motor pulley/spring etc. while the machine ran its cycle. EVERYTHING is working as it should, except the belt itself will only spin erratically, like its not catching. We (my Dad and I) have gone over it multiple times to make sure that everything is on properly, and functioning properly, and we can't see any problem besides the belt not catching. We used belt #37820, which is what's indicated for the machine. I checked other responses, and found nothing that helps. Could we have possibly been given an improper belt size? The belt IS stamped with correct number
  • Ancient god of gaming
    Ancient god of gaming Oct 15, 2018
    Yes, you're right. Part number definitely checks out. I would go around the motor mounts and tensioner and look for anything that has shifted or unexplained bolts holes/anything that doesn't line up or appears broken. Also check that you have the belt routed correctly. Go to 3:28 on the attached video to see the belt path on the pump/tensioner assy.
  • Sharon Devan
    Sharon Devan Oct 15, 2018
    So we double checked bolts, alignments etc. and everything looks good...the belt just will not catch all the time, sometimes not at all. We're really stumped here.
    Hmm, this is tricky. In the video I can see how the tensioner works and there's no reason why the arm and pulley shouldn't pull back into position once the belt is installed. Only 4 possible sources of fault - #1: belt was defective from factory (it happens...) #2: tensioner pulley is worn down #3: main motor mounting bushes have worn out causing the drive to pull closer to the agitator pulley (I'd think it would be noisy as hell before that happened) #4: tensioner pivot bolt is worn out (again you'd know it by the assembly rattling and the belt wouldn't stay in it's path) Other Amana owners have experienced a similar problem (sorry this is turning into a novel) I have a possible PERMANENT fix. Take the plastic pulley and the belt off and go into a belt & bearing shop and see if they have in stock a pulley with the same diameter bearing but a slightly larger outer pulley diameter or a shorter belt. Either of those options should theoretically take up the slack and solve the slipping belt. If this works, please add a testimonial, a tip and a relevant part # and source for the pulley or belt.
  • Sharon Devan
    Ok. We are going to remove the belt and measure it for correct sizing. We are then going to see if the pulley trick will work. This is so weird!
  • Sharon Devan
    Sharon Devan Oct 17, 2018
    The plastic cover on the tensioner bolt had fallen off and rolled to the back of machine. We found it, put it on, and that took up the slack in the belt. Yay...it all works great! Thank you for all of your help! If we hadn't it, I was going to try your idea, or adding a cap or something on that bolt!
    Ancient god of gaming Oct 17, 2018
    You're welcome :)
SOURCE:
sdmc73
  • 121 Answers
SOURCE: amana lw8252w2 changing belt
there are 3 screws that hold the pump to the moter but sometimes it is rusted so you may need to pri it off
Posted on Nov 29, 2008
SOURCE: AGITATOR
I bought an nav5800aww used and had the same issue. Mine was due to the coupler that attaches the auger to the agitator being worn out. I fixed it by removing the auger by pulling it up off the agitator, and putting four small screws through the tabs so that the points of the screws were pointing out. When I replaced the auger, the screws held it in place. That fix lasted about a year, but the plastic eventually got torn up enough that it doesn't work any more. You can find a replacement part online pretty easily
Posted on Feb 15, 2009
SOURCE: how to put on a new belt for Amana washer model #LWA50AW
I just did this today. You have to remove the motor. first start by removing the two hoses then remove the four 1/2 inch bolts that hold the motor/pump assembly. the wires are clippes to a bracket, pry that off removr the whole motor assemly with the bracket by pushing on the tub to manipulate it out. Then remove the three #25 torx screws that hold the pump to motor, remove the pump then route the belt onto the pulley around the inside pump mount put the motor back on the reinstall it the way you took it off. its not that bad (for the first time ever working on a wash machine). I hope you dont have the problem I do, the belt slips in the spin mode - that is probably why the belt failed in the first place I am still trying to find a solution to that. if you just have a failed belt, you will be just fine.
Posted on Apr 10, 2009
SOURCE: cant remove the pump to change a belt
I ended up breaking the pump. I found that there is no real trick, it just gets stuck on sometimes. I worked on removing it very carefully for a couple hours but in the end the plastic cracked and needed replaced. The pump cost me $48 to replace and then the rest was easy
Posted on May 25, 2009
  • 901 Answers
SOURCE: install belt on Amana top load washing machine
Use the correct sized belt!!
Loosen the Motor mounting Bolts. ( Do not take it off ) Now the motor assembly can be moved towards the opposite large pulley.
Replace the belt in this position and slide the motor to it's original position. You adjust it in such away so that, the belt is not too tight or loose!
Posted on Apr 06, 2010
Amana LWA50AW spins slow or not at all
No spin, or lite spin try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand.
May 27, 2014 | Amana Washing Machines
Washer fills, agitates, won't spin. Makes buzzing noise. Amana LWA50AW
Most likely it could be the forward belt . When the machine is under load you hear a winding noise it sounds like the pulley belt tensioner. One other thing to check the rinse and hold button is activated as in the past accidentally people have switched it off.
Jul 26, 2011 | Amana 3.2 cu. ft. Top-Load Washer
Washer will not agitate or spin
If the unit hums and sounds like it's running but doesn't spin or agitate you've probably got a bad coupler. Open the unit and take the pump and motor off and see if the coupler is broken or missing (This is most often a plastic/rubber part which usually breaks down into three pieces and hooks your transmission to your motor). If it is missing or damaged, replace it. Good luck.
Apr 06, 2011 | Amana ALW480DA Top Load Washer
Install belt on Amana top load washing machine
Apr 05, 2010 | Amana ALW895 Top Load Washer
The washing machine belt will move to agitate, but will not move to spin. The spin action burns up the belt. This is an Amana LWA50AW
open rear cover , see if belt slips. then remove belt and rotate empty drum if its jam than drum bearings need to change. if drum is free then belt might be loose and needs replacement.
Nov 05, 2009 | Zanussi FJS1225W Front Load Washer
Cant remove the pump to change a belt
May 19, 2009 | Amana Washing Machines
How to put on a new belt for Amana washer model #LWA50AW
Apr 09, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Amana Washer LWA50AW doesn't spin
Ifi t does not spin it may be the timer. Try it in the delicate cycle to see what happens. Actually try all teh cycles to see if it spins in one of them. IF so it most likely is the time and is a 15minute job to replace.
Feb 26, 2009 | Amana ALW480DA Top Load Washer
Washer wont work.
I FOUND BROKEN BELT . HOW DO I CHANGE IT ?
Apr 27, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Washing Machines Logo
137 people viewed this question
Top Amana Washing Machines Experts
Sal De
Mike
Gerry Harvey
Gerry Harvey
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
