Question about Bulova Watches
What is the battery I need for a Bulova rr955 q watch
SOURCE:
SOURCE: watch casement cover replacement
looking for a battery cover to suit model D 377 tissot men's twotimer II vintage 1992.
Posted on Oct 20, 2008
escapement
  • 2338 Answers
SOURCE: bulova computron watch batteries drain
Here is all the details you need for repairing your watch:
www.bulova.com/service/inside.aspx - 4k - Cached - Similar pages
Posted on Dec 22, 2008
  • 2501 Answers
SOURCE: I have a bulova 98m36 ladies watch and I need to
I advise you to take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving.
This is particularly true if you watch is sealed as replacing the back can be difficult.
Posted on Feb 18, 2010
gemineye61
  • 831 Answers
SOURCE: just replaced the battery on
If you have had your watch awhile, it probably needs a clean/oil/adjustment. FIne watches need regular mainentance just like a car. Take to a local watchmaker or send to following:
http://www.bulova.com/service/servicecenter.aspx#inside.aspx
Posted on Aug 19, 2010
tbreeze47
  • 3083 Answers
SOURCE: How do I remove the back of my Caravelle by Bulova
There is a special gear type tool with prongs on it that rotate the back of the watch off (turn to left to take off, right to replace). If you don't have one, take the watch in to a jeweler's and they will replace the battery for little or nothing, usually.
Good luck, and hope this helps.
Posted on Nov 29, 2010
Battery size for bulova 98g48
If there is a dead battery in the watch, when it is opened, that is one way to identify the battery size.
A second way, if no battery left in it, is to go to a local jeweler or watch battery replacement kiosk at the shopping mall.
Third, contact Bulova at phone number shown:
https://www.bulova.com/pages/manuals-parts
Parts Manuals
Jun 15, 2018 | Bulova Watches
Which battery number should I use on a bulova 96t63
Most likely...
Bulova 228 = S05 American Watch institute, USA: 357 (303)
Japan: SR44W .. (SR44SW)
Possibly...
Bulova 606‎ = S32 AWI... Energizer/Duracell 377 or SR626SW
Which battery number may use in this watch bulova 96t63 thanks
and
Specialty Battery Finder
Jul 28, 2016 | Bulova Crystal Ladies 96T63"
Wich battery number may i use in this watch bulova 96t63 ??thanks
cant see that model watch on the Bulova web site user manuals
http://www.manualslib.com/brand/bulova/watch.html
if unsure if it needs a battery go to a jeweler or watch or battery seller
some model Bulova Watched instructions
IF YOUR NEW WATCH IS A MECHANICAL WATCH
(no battery)
Mechanical watches differ from Quartz watches in several
respects:
1. No battery changes are needed - they are powered by a main-
spring, which is wound either by wrist movement; or in some
models by daily winding of the setting crown.
2. Because it is a mechanical device, it's accuracy is subject to
the effects of gravity and temperature. You can expect, on the
average, a daily variance of up to 10 to 20 seconds for
mechanical watches.
3. Just like automobiles, these watches require routine mainte-
nance. Due to their mechanical complexity, mechanical
watches require cleaning and new lubrication every 3 to 5
years to run at optimum efficiency.
FOR THE AUTOMATIC SELF-WINDING
MECHANICAL WATCH
it must be wound at least six or seven times before you wear it.
After that, your daily activity should wind the watch sufficiently
to keep it running at night when it is not being worn. If your
normal daily activity is not sufficient, occasional supplementary
manual winding may be necessary. It is suggested that your
mechanical watch be cleaned and oiled periodically to insure
optimum performance. As a mechanical watch, quartz watch
accuracy cannot be expected. References to the power cell do
not apply to Automatic watches
May 02, 2016 | Bulova 96T53 Watch for Women
How do i change the battery of a Bulova 96L37 watch
take it to walmart and let them do it . of any god watch shop . you need a case press to put it back together without breaking the front crystal
Feb 14, 2015 | Bulova Watch
New watch bulova 96R-19 women, and dont know how to start...
I have read the instruction for this watch and I am surprised how little they tell you!
The description of the watch does not say if it is automatic or battery driven so I shall give you two alternatives to try:-
1) If it is battery driven, then there may be a wedge under the winder to prevent it going into the running position (to save the battery while it is on the shelf). Pull this out and push the winder home.
2) If it is automatic, then it is mechanically driven by a spring and needs to be wound up. This is done by either turning the winding knob or gently shaking it from side to side form some minutes. Once going, such a watch needs to be worn daily to keep it running. They will normally run for 1 - 2 days before stopping when not being worn.
If you were not given instructions with your watch, you can get them from their web site http://www.bulova.com/brands/bulova/product.aspx?origin=sku&sku=96R19&brand=bulova.
Dec 22, 2010 | Bulova 96R19 Wrist Watch
Just replaced the battery on the Bulova Ladies bracelet watch. watch keeps stopping still.
Aug 19, 2010 | Bulova Crystal 96T63 Watch for Women
Bulova Watch Millennia Motion 96B17 - stops - needs battery????
Dude, of course it stops during the night - it's a perpetual motion / kinetic watch. It doesn't have a conventional battery. When you move your arm (while wearing it), the natural motion of your arm will 'automagically' wind the watch. There's nothing wrong with it - these types of watches always have to be re-set in the morning if you don't wear it to bed (or you don't toss and turn in bed).
May 30, 2009 | Bulova Millennia World Time 98G66 Wrist...
I have a bulova 96b34 that has a rechargeable battery but needs a new one.the battery has a little welded contact on the back and i have no idea where to find one.
Batterie model is Panasonic MT920. You can order a Citizen part no: 295-5600 who is a rechargable batterie for watch mouvement Miyota model BR10. That mouvement is use in Bulova motion quartz, Invicta automatic and Citizen eco drive.
Jan 08, 2009 | Bulova Millennia Motion 96B34 Wristwatch
Watches Logo
76 people viewed this question
Top Bulova Watches Experts
Arturs Kalnins
Arturs Kalnins
Anthony Ward
Anthony Ward
Are you a Bulova Watch Expert? Answer questions, earn points and help others
