SOURCE: mdb7601aws dishwasher door drops down
hi there,
go to www.whirlpoolparts.ca to get the exploded view for your model #. it will be the located under Repair Parts.
SOURCE: Dishwasher door spring
remove the lower kickplate open the door hook the spring on the hooked part of the door and then in one of the holes in the frame youll see
SOURCE: F & P dishwasher 913T/87198 - ? how to replace door springs
I have done this on another make, but most front loading are very similar see pictures and solution here:
http://www.howtofixanything.co.uk/howto-260.html
SOURCE: Kitchenaid DW door spring
The door hinges are spring-loaded. One or both hinges have failed.
Items 2 and 3 at the link below are the parts that are needed.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5135727
I am not aware of a service manual posted on the internet.
Hope this helps! Please post back with what you end up doing, OK?
Good Luck!
SOURCE: Broken door spring on Kitchenaid dishwasher
you have to pull the unit totally out so you can access both sides of the machine you can order the parts from either marcone or allbrands applaince they mail the parts directly to you when you have the unit out you will be able to see its an easy fix of just replacing springs and cord if im remebering correctly theres only two 1/4 screws to loosen one on each side you will be replacing the glide rollers also in the kit they send you with the cord are the glide rollers
