You can get Blaupunkt radio codes for a small fee from this link:
https://www.gumtree.com/p/in-car-audio-gps/car-radio-codes/1317633276
Radio codes from this link:
https://www.gumtree.com/p/in-car-audio-g...
Post the full BP Serial Number
Radio Codes and advice are always available here
www.ukbookshelf.co.uk
Mention FixYa Forum
Dealer with vin
SOURCE: need code for blaupunkt car 300 astra 1998 car
The radio will have to be removed from the car dashboard .Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
SOURCE: blaupunkt radio security code not working on my Holden Astra
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
note: Unfortunately not all radios can be decoded using the Serial Number
If not then try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
Here is a video showing how to remove your radio from the dashboard. A pair of extractors are required (available from Ebay , etc) but these can be made from 2 pieces of bent, wire coat-hanger or 4 small drills(using the blunt end) or 4 small Allen Keys or 4 small screwdrivers or 4 nails or even 4 darts.
An assistant is useful to pull the radio out whilst you are releasing the 4 securing clips
http://www.fitaudio.com/videos/din_keys_guide/video_din_size.html
SOURCE: 2002 Holden Astra 'Blaupunkt - CD player' MANUALS on the net?
This is a link to Blaupunkt for manuals, I don't see your paticular "model" though. See if you can locate it.
http://www.blaupunkt.com/us/downloads_1.asp
SOURCE: Need a wiring diagram for
On your Blaupunkt 520 player you can see the diagram .It should be like this
Thank You
SOURCE: I have 3 Safe on
Your code is 3352
To reset from 3SAFE leave the radio SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself
