Grainger usually has the best products at a reasonable price
Silicone Aerosol,11 Oz. Item # 44N745 Silicone Aerosol, Container Type Aerosol can, Size 11 oz., Temp. Range -40 Degrees F to 500 Degrees FVOC Content 55 Percent, Specific Gravity 0.72O-rings
please see the video and proceed according, LUBE the rollers bearing very IMPORTANT! However , if the problem persist your must test a) main motor+belt b) main control motor board see the block diagram attached. God bless you
Check the fuses under the lower hood. One should be a 10 amp fues, the other should be 15 amp fuse.
Replace them if blown. If they should blow again, move the treadmil to an outlet closer to the fuse box/breaker box of the house. the house wiring where you have the treadmill may not be adequate for the treadmill.
Hope you didn't finish download or install your programe properly so it remind you to upload or update your programe/software that you install.
First of all try to find out that pop-up result and then un-install or install it properly and see whether it happen again.
Thanks fr using FixYa
A treadmill will shut down from to much friction which is due to high motor current because the walkbelt and deck are not properly lubricated. I would recommend replacing the motor controller,walkbelt,deck and applying .5 oz of lubricant on the deck every 3-6 months or 100 hours of use. This will extend your treadmill's life many years.
If manufacturer and google are of no help, ask them. They already found some hard to find Reebok manuals. I guess they have the TR3 for download on their site.
Did you try it before you bought it and it was working. when you move the unit and pluged it into the wall outlet was it on? if yes then you may have damaged the lower board. If you can not get that part then the treadmill has died. Is it a Bowflex or a Free spirit.
