Question about Leviton Electrical Supplies
Does a leviton slide dimmer switch use regular bulb's
    Top Expert:
  • Leviton Master
  • 53,746 Answers
What do you know as "regular " bulbs
are they low energy or incandescent
Posted on Oct 11, 2018
SOURCE:
  • 417 Answers
SOURCE: leviton slide dimmer switch w/locator light light comes on but doesnt dim
What sort of light is it , dimmer switches normally only work on Incandescent type lights not flourescent type.
Otherwise it sounds as if the dimmer function is faulty.
Posted on Nov 03, 2008
  • 44 Answers
SOURCE: newly installed Leviton dimmer switch humming at the switch
You'll need to install an electronic dimmer, like a Maestro. Otherwise, you'll have to live with the hum.
Posted on May 30, 2009
  • 23 Answers
SOURCE: Light dimmer issue
the light on the switch does not men it is wired correctly, it only means that you have supplied power at that point. Without knowing more its hard to say, but I'll assume this is a single switch operating a single unit. That being the case, and depending on your fixture, occassionally wires must be grouped together on the switch side. Also quite often these switches are simply defective, and must be returned. If you think you have it correct then its probably a bad switch.
Posted on Jun 17, 2009
  • 112 Answers
SOURCE: touch dimmer malfunction
sounds like a loose connection to me, check to make sure all connections are tight. sometimes the bulbs themselves don't make a good connection in there socket.
u will have to take the switches out of the wall box and make sure the wires are tight, whether they are on screws or wires connected to wires. if it is wires to wires u may have to take that apart to make sure u don't have a bad connection there.
if it is none of that, then it is time to replace the switches
Posted on Aug 21, 2009
  • 152 Answers
SOURCE: why do dimmer switches make my lights change in
this is a tricky one.. when i inquired to the maufacturer they came up with several reasons.. dimmers are electronic and any electronic noise on the line can cause it to freak out...when it is on full the dimmer is not engaged. When the dimmer is dimmed the electronics kick in and are subject noise. Ahh what is noise? noise is caused by motors, or transformers (like phone chargers) or god knows what. you can try to move the circuit breaker from one leg (phase) in the panel to the other. that might doit.. or the noise could be coming from your outside your home or if you are in an apartment.... anywhere..... you can try fo put in an old resistor type dimmer if you can find one... then when it all starts to work... your wife will say... whats the humming noise!... and thats another story.. use candles
Posted on Dec 06, 2009
Dimmer slide does not dim
Replace it. They fail and and that is not uncommon. good luck
May 20, 2018 | Leviton Electrical Supplies
Humming and failure to dim
Bad dimmer. Probably not using a high enough watt rated switch. Add up the total of all bulbs to be dimmed and get appropriately rated dimmer. 8x60 watt bulbs=480 watts. Make sure dimmer is rated high enough.
Feb 09, 2014 | Leviton Decora Light Dimmer Switch
I am replacing a Lightolier 3-way Dimmer switch with a Leviton IPI06-1LX Dimmer switch. When I install the dimmer switch it works fine. But the on/off regular wall switch won't turn the light on or...
It depends. Some dimmers are considered "smart dimmers," where the control on the other end of the 3-way has to be intelligent enough to send a signal back to the dimmer. If the Lightolier dimmer was a smart dimmer, then chances are that the 3-way control was designed to talk only to that specific dimmer. The Leviton product you replaced it with is a simple, basic dimmer - it should work in conjunction with a simple, basic 3-way switch.
If the 3-way control already IS a simple, basic 3-way switch - then I would simply re-check the wiring of the dimmer you replaced.
Sep 11, 2011 | Electrical Supplies
The dimmer switch will turn on and off but wont dim the lights on a chandelier. model 6681-w. tried 2 different ones with the same results.
The Leviton 6681 is a push-button rotary-type incandescent dimmer with 600Watt capacity
If you have incandescent bulbs, the dimmer should work.
If the dimmer has different color wires, try reversing the wires.
If the dimmer replaced a 3-way switch, then this is not the right dimmer.
If you have compact florescent bulbs, you need a dimmer that also dims florescent.
http://www.google.com/products/catalog
Link shows the Leviton 6673 incandescent and florescent dimmer
But you also need dimmable compact florescent bulbs.
http://www.amazon.com/DIMMABLE-COMPACT-FLUORESCENT-LIGHT-SPIRAL/dp/B0014B84ZM
Oct 31, 2010 | Leviton #L11-06681-00I Ivory 600 Watt Push...
Hi, I have a leviton slide dimmer controlling 4 pot lights with gu10 bulbs. There is also 6 receptacles on this 15 amp circuit. I had a regular 2 pole switch on there, with no problems. When I converted...
You said they are 50 watt GU10's, so I would assume they are 120V halogens, and you must simply have gotten a bad dimmer. But if these GU10's are 50 watt equivalent (LED's or CFL's) then the bulbs will have their own transformers built into them, and would be incompatible with a dimmer switch. It also might be the case that you have low voltage halogens which would use a transformer, shared or individual, and these would also be incompatible with a dimmer. (I don't know offhand if GU10's are available with low voltage halogens.)
Sep 17, 2010 | Leviton WHT SLIDE DIMMER
Dimmer turns on/off 3 spotlights but they wont dim
Questions to answer so I can answer/resolve your problem:
1) Is this a rotary style dimmer?
2) Is it a toggle or slider type?
3) Is this on a 3-way circuit (that has 2 or more switches that can turn the lights on or off)
4) Is this on a single switch circuit?
5) Is this a brand new dimmer switch?
6) Is this an old dimmer switch?
7) Are the light bulbs in the spots regular incandesant or halogen bulbs?
8) Are the light bulbs in the spots CFL (compact flouresent lamps)?
With this information, I can tell you what the problem is:
If you answer "YES" to #1, and or #6 then the dimmer is faulty and should be replaced.
If you answer "YES" to #8, then you have the wrong dimmer for the bulb type, as CFL's require a specific dimmer type in order to dim them.
Please provide some more info and maybe we can help you figure out what's wrong.
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | Leviton Electrical Supplies
Light dimmer issue
Jun 17, 2009 | Leviton Decora Light Dimmer Switch
New Leviton 'lighted, decorative' switch flickers when off
You cannot use standard electronic dimmer switches with CFL bulbs, only incandesant bulbs! That is why you are getting the flickering.
With CFL's bulbs installed in a light fixture that has a non-flouresant rated dimmer switch on that circuit, you will cause the standard dimmer to fail.
You have to look at the dimmer package (sometimes printed on the back of the dimmer itself too) to see if it can be used with CFL bulbs,as many are not rated for use with anything other than standard incandesant bulbs.
Hope you found this very helpful and best regards!
May 31, 2009 | Leviton Decora Light Dimmer Switch
Leviton slide dimmer switch w/locator light light comes on but doesnt dim
Nov 02, 2008 | Leviton Decora Light Dimmer Switch
Electrical Supplies Logo
55 people viewed this question
Top Leviton Electrical Supplies Experts
jdthefixer
Gene Haynes
boomanfoo
Level 1 Expert
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
