SOURCE: Water Leak
is the pump gray or white? if it is gray then replace it.look where the pump mounts to the ,otor and see if there is a black line coming from the middle.this is probably where your leak is.
just change the pump.
SOURCE: "nF" error code at end of cycle, and water leak
nf means u have a bad water valve u may also have a bad hose underneath the lid as well if u have water in your control
SOURCE: changing fill hoses---the connection to the washer is very narrow
Are the rubber gaskets in place on the hoses? Some hoses come with rubber gaskets others do not and they have to be inserted.
SOURCE: Washing machine leaking from bottom.
maytag pav2300 washer leaking at pump..should I replace entire pump or just seal? also, screeches to a stop....what is causing this?
SOURCE: My toilet only leaks when flushed. It seems to be
If you have 2-part toilet, then tank is attached to bowl with 2 bolts.
Look inside tank and you can see bolts with rubber washers located on either side of flush valve.
The 2 bolts hold tank and bowl together and between tank and bowl is a washer called the spud washer.
So spud washer could be leaking ... or 2 bolts could be leaking.
1) If bolts are leaking, there is usually dripping all the time, and drips are visible on bottoms of bolts
If spud washer is leaking, then tank could leak only when tank is flushed.
2) First thing to try is tightening nuts on the 2 bolts. Nuts may be loose. Tighten nuts a few turns, and check if toilet still leaks.
3) To fix a spud washer, you usually need a new generic one from hardware store.
Newer tanks with 1.6 gallon flush have special sized spud washer.
Tank is upside down and spud washer is fit over flush valve
If you cannot find new spud washer, re-use old one and smear retorseal on it during re-assembly to make sure it seals. Rectoseal is good for many home plumbing repairs. More about that in a moment.
4) To take apart tank: Disconnect supply line to tank. Empty water out of tank. Remove nuts from bolts. Lift tank off. Wash out tank with hose. Make sure there is no sand or sediment left in bottom that might clog up flush holes located inside bowl after tank is re-assembled.
5) Remove old spud washer, and put new one on. Do a google-image search for 'spud washer' if you need more photos. New spud washer fits over flush valve. That's it. And then reassemble tank.
If you want to apply rectorseal to washer, put washer on as shown in photo above. Then smear-or-gawm rectorseal over area of washer that sits on bowl. Rectorseal will make sure there is no more leaking.
Hi
If the washer won't fill you'll need to check for the water
inlet hose, the water inlet valve and the pressure/water level switch assembly.
Inspect the inlet hose coming to the washer for any blockages. If the hose is
not clogged then check the water inlet valve for any clogs, if the water will
not even fill for few seconds then certainly the water inlet valve is bad and
should be replaced. You can also use a multimeter to check continuity on inlet
valve. If you don't get any value on the multimeter then you'll need to replace
the water inlet valve assembly. However, if the valve is fine then the
pressure/water level switch assembly should be replaced. Hope this helps...
Please post back if you need more information.
Daniel
Hi
This is either the large pipe that connects from the bottom of the outer drum, to the suds pump inlet, or the pump bodies itself, or the seal inside the pump. This may be tricky to work out where the leak is coming from, but just use a good torch, with the back removed, and watch it through a short cycle. If it is a plastic pump, they usually have small screws holding the 2 parts of the pump body together. Try tightening these, if they are loose. Also if the machine is over 8 years old and has had a lot of use, it will most likely be the pump seal.
Please get back to us if you have further query else please accept the suggestion. Thank you for contacting fixya.com
