Question about Subaru Audio Players & Recorders
Subaru 2019 CD player too long a space between tracks on cd player
    Top Expert:
  • Subaru Master
  • 84,625 Answers
If you think it is defective remove it and send it in for repair, there are no parts or info about repair sold to the public.
Posted on Oct 11, 2018
SOURCE:
SOURCE: CD player skips on early tracks
The lens assembly in a CD player glides along on a two rail track, kinda like a railroad track except tubular. The lens carriage is moved over this track by a small motor driving a worm gear. (Think long, tubular and spiral). If the rail tracks or the worm gear dry up or have dust accumulating on them, this could be the cause. Normally they have a light gear oil or lithium grease on them to keep them lubricated.
Posted on Mar 10, 2008
  • 102 Answers
SOURCE: cd player does not work and cannot unload cds already inserted in
This is common with OEM changers and is the leading reason for upgrading to aftermaket audio systems......you can try blowing compressed air into the CD slot, if the problem is dust related this may help.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Posted on Mar 10, 2009
  • 85 Answers
SOURCE: Need a stereo wire color code for 2000 subaru outback limited
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Green/Black
Right Front Speaker Positive Wire (+): Red/Yellow
Right Front Speaker Negative Wire (-): White/Black
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Red
Left Rear Speaker Negative Wire (-): Red/Green
Right Rear Speaker Positive Wire (+): Blue/Green
Right Rear Speaker Negative Wire (-): Red
window.google_render_ad();
Posted on May 17, 2009
ghost4548
  • 776 Answers
SOURCE: cd player showing error 43
Still under warranty?... check that.
Posted on Jun 20, 2009
sodeep
  • 3267 Answers
SOURCE: CD player has no sound - Bose wave radio/cd player
Amplifier chip/circuit is kaput. Unless you are familiar in fixing electronic equipments better to give it for repairs................sodeep
PS. Buying a new one will not be cost effetive unless you need a change!
Posted on Jun 28, 2009
JVC XL-R2010 CD Recorder - recording dao problem
Reading the manual over and over, it looks like there is a function called Autotrack and by default is ON.
In the manual, page 22, shows you how to put the Autrack OFF.
Be careful that if you use the synchronize one-button recording you will have again the Autrack automatically ON again and that means a pause or bump between tracks.
For your reference I used the manual at this location http://resources.jvc.com/Resources/00/00/98/A0013ien.pdf
Please let me know if you need further help.
Oct 28, 2007 | JVC XL-R2010 CD Recorder
We have Marantz PMD 325 CD players. Usually TOC REading comes up when you put a CD into the player. However sometimes we now get the following message "PMA Reading", What does this mean.
Hi Wendy CD-Rs and CD-RWs have a component that ordinary music CDs do not have -- an ...This additional track space includes the power memory area (PMA) and the ... which tells the CD player what part of the disc it is reading at any particular time. ...uncorrected error on a music CD only means a bit of fuzz or a skipping noise. GOOD LUCK !
Jan 05, 2014 | Marantz SA8260 CD Player
Audio formats supported by kenwood kdc 719
My older CD player accepted WAV files when I burned them as Audio CDs. (I was able to add CD-Text, even though my player can't read the text. The disc I added space between the tracks though didn't work properly.)
Then do a mastered burn (disc at once) and finalize the disc. I used CD Burner XP for burning the latest batch and Audacity to create the WAV files. I've also use Roxio Creator and Nero in the past.
I hope this helps.
(I'll admit there's one issue - I can't get the disc to stop between tracks. I was copying audio tapes to CD before more of my tapes broke.)
Apr 29, 2012 | Kenwood KDC-719 CD Player
Hi,\r\n I have a hl-dt-st rw dvd gcc 4521b cd burner, and I am not able to burn CD's with no space between tracks. Even if I set in Nero that the CD will be burn with no spaces between tracks, I get 1...
which nero are you using nero burning rom will automatically space between songs hope fully the nero you have will have similiar seetings available
The following check boxes are available:
General
area
Normalize all
audio files
Enables a filter that brings the volume of the audio files to be
burned into line with one another. This is particularly
recommended if the audio files originate from different
sources.
No pause between
tracks
Allows the audio files to merge into one another on the audio
CD without a pause (just like in live recordings).
If the box is unchecked, there are pauses of two seconds
between the audio files.
CD Text
area
Write on CD
Enables the option for writing CD text. With CD players that
support CD text, the title of the CD, the name of the audio file
as well as the name of the artist appear in the display.
In the
Additional Information area you can enter additional information about the audio CD
such as the producer or comments for instance.
hope this helps
Apr 15, 2011 | LG Computers & Internet
I recorded something on the CD, and it can not be read on my Mac or my CD player. I also need to delete some tracks from the CD but don't know how since it can't be read.....Please help.
if you go over the recomended space on a cd and it burns neway it will make the cd unreadable because it couldnt complete the finalization process reburn it on your pc with less tracks.
Jan 30, 2011 | Maxell CD-R 80 Minute 700MB Media...
Playlist exceeds disk space will not allow to create cd
Delete tracks from the playlist to bring the total time to less than the maximum available on the CD. If you're trying to write a redbook CD this will be just under 80mins, less if you're using higher sample rates and CD24 discs.
Nov 30, 2010 | Alesis MasterLink ML-9600
On my Marantz CDR-630, how do you erase unwanted tracks after recording and before finalizing. I see there's a "erase" button but it won't do anything. Fred, fred@katli.com Thanks!!
Which recordable disks are you asking about? "Erase" will only work on CD-RW and does nothing on CD-R.
Once you've recorded onto CD-R all you can do is add additional material to it until the disk is finalised to allow it to be played on virtually all CD players. The same goes with CD-RW, but with those you have the option to erase the entire disk and start again from scratch. You can also delete individual tracks from a CD-RW but the space does not become available for additional recordings until the disk is totally erased.
Perhaps you'll find the .pdf manual to be of use:-
http://www.vegalab.ru/forum/attachment.php?attachmentid=65482&d=1256129031
I hope that this has answered your question, all I ask in return is that you return the favour by rating my answer.
Nov 05, 2009 | Marantz CDR631 CD Recorder
No cd or cd track info
only certain cds have the track info on them. most cds will just come up as a track listing. some cd manufacturers put the track info on at production but most do not. try to burn a cd and label
all of the tracks as well as name the cd. if it does not show the names then something else might be up.
Dec 22, 2007 | Jensen's VM9312 Car DVD Player
47 people viewed this question
Top Subaru Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Subaru Audio Player and Recorder Expert? Answer questions, earn points and help others
