The
safest method to measure the amount of stools needed is to measure the length
of the counter top and then divide that number by two to roughly determine the
number of stools that should fit at the counter.
there should be a clamp on the end at the balljoint with a nut loosen the nut and take two wrenches. one on balljoint other on bar . scraw ball joint off. remember measure length of bar with old ball joint to middle of ball. when reinstall new one screw new one in to same measurement. hope this helps.
The only true way to get the proper length cables is to go ahead and change the bars. Then, use stiff wire to "mock up" the cables. Once you do this, measure the wire to get the length you need. Then , go to this website and see what you need. If you need custom cables, you can order them here. http://www.barnettclutches.com/products/custom_measuring_guide.aspx
loosen bar nuts, with gloved hand push up on bar, and turn adjuster screw clockwise. on stihls it's either beside bar facing forward or between bar nuts.
What is written on the Bar? If your Bar is a 22" then the chain will be packaged for that length Bar. Make sure you get the correct model chain for your saw.
