Craftsman Rototiller
I have the same unit, although newer, and just recently, the carburetor got gummed up, and I'm waiting on a rebuild kit. Well, I've been noticing the gear shift isn't as smooth as it could be, and since I've been curious about the drive mechanism, I decided today to split the case and see what the guts look like. Here's what I found. The input shaft is splined, and has a floating gear that is moved along the length of the shaft by a lever attached to the gear indicator outside the case. As the gear lever is moved, this gear engages the other larger gears for reverse, forward, and till. Both the tines and the wheels are chain driven, the tines by a beefy 60 series chain, and the wheels by a smaller 30 or 35 series. There is NO oil. The housing is filled with grease, or rather, should be. Not long after I bought my machine new, I took it for a service to my favorite power equipment place, where we have shopped for over 30 years. They told me they greased up the housing real good, since it sounded 'dry'. Today I noticed what they did. The factory grease was black, while our shop, A-1, uses a premium red bearing lube that all the farmers in our area use for their machines. We swear by it. Anyway, A-1 added probably at least half a tube to the case, and judging by what I saw today, it needed at least that, and probably more. Well, here is the big problem with the drive on this tiller. Chains. . . stretch. New ones stretch quite a bit, and if it stretches enough, the chain will ride over one of teeth on the sprocket and either break the tooth, or more likely, snap the chain. Considering that the entire machine needs to be stripped down to split the case, this design is problematic. A gear unit would be almost maintenance free. Before I put this thing together, I plan to shorten both chains at least half a link, and pack the housing with a good lube. There is a token zerc fitting on the upper part of the machine just above the
input shaft. It simply pours grease into the inside of the
housing.
