First a fault code on your Xerox printer and or multifunction device is not always as disastrous as you might imagine, no reason to slink away from the machine. The fault code is just a way for your machine to tell you there is a problem and it needs some help. So next write down the complete code and any accompanying error message, the fault code will be numbers and/or letters and may include commas, periods or hyphens. Then find a device on which you can access the internet. At the computer or smart device go to Xerox.com and then select the Support & Drivers tab at the top. Enter the model of your Xerox printer or multifunction device in the field provided and then select the machine and select Support. On the machine support page you will see the "Search For Keyword or Phrase:" field. You can enter the fault code there or right under that field you can click on the "Fault Code Search" link. A new screen will be displayed where you can enter the fault code or you can scroll through all the codes looking for the one you wrote down from your machine
SOURCE: error codes
If thats a flashing E 7 that is related to the optics or laser.
There normally is a second code if you press 0 it will then mean E 7-1 to Check if the lamp is comming on.
Extremely dirty optics would give you a set up code E 7.
The Laser could be defective.
The main board may have gone bad.
I would start by cleaning all of the optice thoroughly. Including the white strip on the bottom side of the glass.
Look for an open filiment section in the lamp, if it is not comming on.
If not one those 2 simple issues, then you most likely have a main board or laser failure.
SOURCE: Xerox WorkCentre M128 - 016 - 782
There is an error in the in the server password or a template setting.
Here is the documentation. Pretty straight forward
Login to the Server was not possible during Scan to Server file transfer.
Initial Action
Refer to BSD 16.1.
Power OFF/ON
Procedure
Set the login name and password in the destination server.
Set the attributes of the Job Template file correctly.
From a client PC, set the same account as the above as a resource using CW.
SOURCE: just asked
The following link will take you to Xerox page that explains how to reset a fault error code
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=452,E=0000000001449575339,K=8952,Sxi=3,Solution=obj(18167)
SOURCE: Xerox Work Centre C2424 System Error
Hi there
I found some thing maybe do for you it may not be rhe right code you have at this moment but it come in handy for you.
31,004.40:6909: it's a mechanical initialization jam error. Pull out the paper tray to make sure it doesn't have a jam. Try also to manually feed some heavy paper or card stock through the printer to make sure the sensor in the preheater isn't stuck.
39,002.40 : DRAM test failure.
39,012.40:56208: "Cycle the power" and if that does not work replace the document feeder.
39,012.41: Document Feeder Optical Failure. Replace the document feeder.
4,0XX.6x: Process Control Software Fault.
· Reset NVRAM and then retest.
· Ensure ground integrity for the system
· Replace the EEPROM chip.
· Reboot the system.
· From the System Setup menu, go to "Information", "Troubleshooting"
· Service Tools menu.
· With the cursor at the top of the Service Tools menu, press both the Up Arrow
· and Down Arrow buttons to display the Hidden Service menu.
· Reset NVRAM is in there.
Also may be handy is this.
4,0XX.6x Process Control Software Fault
Error 04,041.66
Solution 1:
a. Reset NVRAM and then retest.
b. Ensure ground integrity for the system.
c. Replace the EEPROM chip.
d. Reboot the system.
1. From the System Setup menu, go to Information --> Troubleshooting -->
Service Tools menu.
2. With the cursor at the top of the Service Tools menu, press both the Up Arrow and Down Arrow buttons to display the Hidden Service menu.
3. Reset NVRAM is in there
Solution 2:
1. Turn the system power ON.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display, press and hold the Back and Info buttons on the control panel.
4. Hold both buttons until the display reads “Beginning Service Mode Initialization”. Release the buttons and the system reboots into service mode with the Service Diagnostics menu displayed.
Hope it will help you in some way of finding the fault.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
