Question about Maytag Dishwashers
Very old Maytag dishwasher stops mid-cycle. Push on door - starts up again. Replaced latch switches. Didn't solve problem. Still stops mid-cycle; push on door, starts up again.Ideas?
    Top Expert:
  • Maytag Master
  • 6,289 Answers
Is latch adjustable to make door tighter?
Posted on Oct 10, 2018
6ya staff
SOURCE:
Anonymous
  • 67 Answers
SOURCE: STOPS RUNNING IN MID-CYCLE
Try placing something like a chair with books or heavy objects on it in front of the door. Tip it with objects under the front legs and place objects on its seat until the pressure closes the door and the dishwasher starts. Put additional objects on the seat to insure vibration doesn't make the door pop open. If the cycle completes, the problem is probably the door switch. If not, the problem may be with the timer switch. If it's the timer switch the dishwasher will probably stop at the same position each time.
Posted on Nov 30, 2007
IFIXALL
Archie Ferrarini
  • 869 Answers
SOURCE: Bosch 24in SHU43, 3 years old
Un plug it for about an hour and  try it again.Its probably built a static problem on your circuit board.
Posted on May 25, 2008
Anonymous
  • 750 Answers
SOURCE: dishwasher won't stop when door is opened mid-cycle
Welcome
You need a new door latch mechanism.
It is faulty and not doing it's job of over riding when the door is opened
Please remember to leave a solved rating before leaving
Posted on Dec 19, 2008
jmgldsmth
Jim Goldsmith
  • 2005 Answers
SOURCE: dishwasher stops during cycle. Have to push on door to start again.
Have someone replace your bad door switch
Posted on May 20, 2009
jamie
  • 1810 Answers
SOURCE: Maytag MDB4000AWA dishwasher keeps stopping. If
door switch out of ajustment
it's a small micro switch that bends from time to time and all you do is bend it back
Posted on Jul 30, 2009
Model MDB7749AWB. Why does it stop mid-cycle?
Defective washer control board is the most common fault.
Mar 15, 2017 | Maytag Dishwashers
Stops mid cycle and resumes after I push on the door handle
Rather than a problem with the latch sensor it just might be that something is preventing the door from fully closing properly. Check that there are no obstructions stuck on the door/frame seals and that the seals are in good order. Perished seals can prevent the door from closing evenly and this may cause the problems you are experiencing. Also check that the door itself is not warped or out of alignment, this will also cause such problems.
Dec 28, 2013 | Bosch 800 Plus Series SHE9ER55UC 24...
My maytag dishwasher will run for a short then stop running, I'll push on the door the machine will run again then will stop again
your door is not staying latched.. imagine if it did stay running and the door came completely open, what a mess that would be. so there are safety switches that help stop the washing if the door opens. not too sure how to fix your exact washer.. but the problem is the door not staying closed. maybe you can jamm the door shut while it is running? its not the best answer, but probably the most free way to fix it
Oct 29, 2013 | Dishwashers
Asko 1385: 13 year old dishwasher stops during cycle. If you push on the middle of the door it starts again. It is like the latch is not working properly but by all appearances the latch works fine....
when you latch the door it closes the circuit.
you may have to open the casing of the door to access the switch. it may be stuck or defective.
May 15, 2010 | Asko 1385 Dishwasher
The dishwasher is probably 12-15 years old. It
Adjust the door lock. Check the door switch wires. Replace the door switch mechanism. In this order.
Oct 06, 2009 | Maytag Dishwashers
Maytag quiet series 200 dishwasher won't start
I had a similar problem. Turn off the power to the dishwasher. Open the door and remove the screws on the back that holds the door together. Now, locate the black control module and remove the cover. Look down at the bottom left of the control module and you should see a ribbon cable. This is the cable that connects the door keypad to the control module. Unplug the ribbon cable and the plug it back in. On my unit the ribbon cable was not making good contact and only half of the keypad was operational,
Hope This Helps !!
James D.
Jul 28, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Nov 30, 2007 | Dishwashers
Dishwashers Logo
196 people viewed this question
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Vitally Alcher
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
