Question about Kipor Electrical Supplies
I need a service manual for kipor kge 12e. Currently it runs but supplys no voltage
    Top Expert:
  • Kipor Master
  • 51,311 Answers
Order the service manual from Kipor.
Posted on Oct 11, 2018
3 Suggested Answers
SOURCE:
SOURCE: ATX -250-12E Power Supply
U need 2 replace ur power supply.
Posted on Jul 23, 2008
  • 3 Answers
SOURCE: upgrade for Bestec ATX 300 12E
Hipro- HP-P3527F3W
is the replacement for Bestec 300W
Posted on Sep 16, 2009
My kipor KGE 6000 Ti generator overload light is on, and there is no current output.
Read the instruction manual. If you are certain you did everything right and the generator does not behave as intended then return it to the supplier as faulty.
Jan 27, 2018 | Kipor Electrical Supplies
Kipor KDE12sta generator under/over voltage LED burning, the engine stops after a few seconds
hi
this happens when voltage regulator is at fault .
what happens is that the demand out put is ( volts /amps too high ) and engine power is too low causing engine to stop renew or service voltage regulator
Nov 12, 2017 | Kipor Electrical Supplies
Kipor 6700ta po5 code problems , diesel silent generator
1. Check the voltage of battery whether is 12V or 24V; 2. The voltage of battery is low when the generator is still, then it is necessary to dismantle the battery and charge the battery with charger.
3. If the voltage of battery is low but the generator is running, it indicates that the diesel engine driven charger doesn't work; then it is necessary to stop the engine to check the fan belt.
4. if the fan belt is not loose, please check the charging AC diesel engine driven charger, please refer to Manual for Diesel Engine.
5. If the battery can not store the electricity, please replace the battery for a new one. https://www.dieselgeneratortech.com/generator-sets/discovery-and-elimination-of-faults-of-the-control-system.html
Feb 04, 2014 | Kipor Electrical Supplies
Speak to us and we can help you diagnose this error.
www.generatorguru.com
Dec 25, 2012 | Electrical Supplies
My kipor KGE 1000Ti starts fine but after several minutes stops generating and the red overload light comes on, with the demand for power left connected and the generator still running electrical...
You may be UNDERLOADING the generator and it may be unstable with such a light load... see if it might behave running a heavier load... put a 100 watt light on it as a test,
Jul 25, 2010 | Electrical Supplies
Upgrade for Bestec ATX 300 12E
Hipro- HP-P3527F3W
Dec 11, 2008 | E-Machines Bestec ATX-300-12E Rev. D 300w...
I need a 5kW DC generator with -48v output.
I have 5kW generators that produce -48V DC. The problem is that unless your generator is designed to produce -48V DC it would be difficult to retrofit an existing AC voltage output with a DC output.
Nov 25, 2008 | Kipor Electrical Supplies
Electrical Supplies Logo
91 people viewed this question
Top Kipor Electrical Supplies Experts
Vernon Taylor
pawnpower
Wayne McNeil
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
