Televison & Video Logo
L
LEXYZZZ Posted on Oct 10, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG 60PV250-UB no picture but ZSUS if unplog picture on
LG tv 60PV250-UB not working but If the ZSUS board is unplug the tV work's kind na
Abctay.com
Level 3:
Master:
  • LG Master 372 Answers
  • Posted on Oct 12, 2018
Abctay.com
LG Master
Level 3:
Master:
Answers
372
Questions
Helped
212274
Points
1385
Just replace your tv power board.
LG EAY62171201 EAX63330001 3PAGC10038A-R PSPL-L014A POWER SUPPLY UNIT https://www.abctay.com/lg-eay62171201-eax63330001-3pagc10038ar-pspll014a-power-supply-unit-p-1875.html
5 Related Answers
Anonymous
  • 487 Answers
  • Posted on Jun 21, 2008
SOURCE: LG LCD/DVD TV no sound on TV - DVD works fine with sound!!!!
HERE is the servce manual for this TV
Anonymous
  • Posted on Jan 11, 2010
SOURCE: LG 42PC3D ZSUS Board Location
the z sus board is the board thats on the right next to the right speaker looking at it from the back, and you can get it at ebay cheap.
Anonymous
  • 3 Answers
  • Posted on Dec 31, 2010
SOURCE: lg plasma 42PC3D no picture with sound
I know you already replaced the board, this is for future searchers. If you heard a popping sound, then the picture went out, there is a 32 pin Sanyo module that goes bad on the board. That's probably what caused the fuse to blow. Replace the module, then replace the fuse. The module is less than half the cost of a used board. Since this was a popular model TV, there are lots of replacement boards on the used market.
Anonymous
  • Posted on Apr 13, 2011
SOURCE: lg 42 plasma model 42pc3d-ud: had a really bad picture so
I Have An LG - 42PC3D-UD, When I Turn It On "It Have Sound And A Very Bad Picture.
Anonymous
  • 517 Answers
  • Posted on Oct 07, 2011
SOURCE: My LG TV 50PJ350-UB TV KEEPS POWERING OFF
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Hi...I have a question my LG tv MODELE NO: 60PV250-UB SVC CODE: 60PV250-UB.AUSZLUR MANUFACTURED: AUGUST 2011 POWER: AC 100-240V ~ 50/60Hz 4.6 A Turned off suddenly and when I turned it on again it only...
The Z sustain board has failed. Due to the age of the unit it may be better to order the kit to service the existing board rather than find a new board. To do the repair you need to be able to solder.
LG 42LN5300-UB TV HAS NO PICTURE AND NO BACKLIGHT
If you power on your TV but you do not see the menu options, or any video display - just a black, blank screen, and possibly no audio as well; try the recommended steps below to resolve the issue. Check if the status LED, in front of your TV is ON. ... To confirm, point the TCL remote towards the TV and press any button.
How to repair a tv LG plasma 60pv250
Sounds like your Power supply is still good. but maybe the board for the video is bad.. (maybe the main board other than power supply. If you do a search on the internet for "60pv250" and "board". you can find replacement parts. If you are capable or know someone with some electronics skills you should be able to see if any parts on the existing boards are popped (sounds like a capacitor went) and then buy the right board
I HAVE A LG 60PV250-UB IT HAS SOUND BUT NO PICTURE. HOW CAN I FIX THE PROBLEM?
replace the power board with the exact same part number on the board it self.
4answers
TV with no picture
Open tv and look at power supply board. ...look for bulged caps...also controller boards could be blown if caps e blown
21helpful
3answers
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
