SOURCE: Sata Harddisk Not detected in Post operation
Hi vijjis,
Make sure your SATA drive is connected to SATA port 1 which is the bottom port. Double check both the data cable & power cable. The data cable only connects one way at the board & at the drive. Same for the power cable. Your SATA drive must be listed in the bios menu & you must list the SATA drive with-in the boot order. If your cabling is all correct & you still do not see the SATA drive in the bios menu than the onboard SATA controller is defective. This can not be repaired because it is integrated into the board. It will not hurt to clear the cmos. See page 15 in your manual. Your board can only run SATA 1.0 = 150MBs. If your Seagate is pinned for SATA II = 300MBs, change the jumper on the drive. (This may or may not work). See if the bios list the drive.
One other option, you can buy a PCI SATA controller.
Here are a few; http://www.google.com/products?q=Promise+pci+sata+I+controller&btnG=Search+Products&hl=en&show=dd
Link to Mercury P4VM800M7; http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=644#
Good luck vijis!
Thank you for using fixya.
Mike
SOURCE: sata hdd
Yes you need to load sata drivers just prior to the xp load screen prior to format.xp will prompt you to load drivers by pressing a key.RICHARDM69
SOURCE: can i install xp-sp3 without Sata driver on motherboard 'DG31PR'
You have a board with 4 SATA ports on it and a SATA HDD. The hardware detection routines will see this and load the SATA drivers. Why would you even want to try to set it up without them?
SOURCE: upgrading my computer
Dear Fried its possible.. Go the Boot Menu at your BIOS ( For go the BIOS Press DEL at startup your system) there you may se Hard Disk Priority Option. There you can change Hard disk Priority... you may need setup your sata as first one..
Thanks...
SOURCE: Will not boot past Logo screen with new XFX nvidia Gforce 9500Gt 1gig card
DD SYSTEM SOLUTIONS
(MOTHER BOARD CHIP LEVEL SERVICE CENTRE)
OLD NO.28, NEW NO.67, II FLOOR
SESHA CHALAM STREET, SAIDAPET,
CHENNAI - 600 015.
PHONE NO : 98405-11595
