Coffee Makers & Espresso Machines Logo
Martin Sanchez Posted on Oct 10, 2018
The steam button on my rancilio espresso machine won’t stay on, it keeps popping out. I have to hold it every time I have to use it. What should I do
2 Related Answers
EsWorld
Ernest R
  • 1618 Answers
  • Posted on Sep 29, 2009
SOURCE: My Rancilio Epoca E1 espresso machine has no steam
It is possible that the reset connected to the boiler tripped.
Anonymous
  • 100 Answers
  • Posted on Feb 13, 2011
SOURCE: Hi. I have a Rancilio Silvia Espresso machine
First of all, your machine is not safe to use so do not use it. A thermostat maybe have shorted out, a wire may have grounded, who knows. Pull the top off and determine where and what has burned out. It should be quite visible.
I have a rancilio epoca 1group. After I turn the steam wand off it keeps steaming. Would it need a new valve?
Hi Daren,
You could replace the whole steam valve wand but you don't need to.
The rubber grommet inside the steam valve is worn out and the tap wont close properly - that is why the steam is coming out.
You will find these parts with a commercial rancilio supplier.
I have a rancillio epoca dual head espresso machine, there are two gages on the front of the machine, steam is coming out of the top gage
You will need to get that manometer changed. Get a hold of a rancilio dealer and tell them you need a steam manometer.
Hi. I have a Rancilio Silvia Espresso machine which has a light that cycles on much more frequently than normal when I am using the Steam option. I have injured the machine somehow, I'm afraid. I was using...
5helpful
I've had my Rancilio Silvia Espresso machine for about a year and a half. I use it every day. Today, it won't heat up. It turns on but will not heat up. Is there a reset button? Help, please.
Hi
There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also another problem that you might have. If the brew thermostat is bad it won’t heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
If none of these things work check the heating element with an ohms meter. The reading in the terminals should be from 12 to 16 ohms. If no reading the elements is bad and you have to replace the boiler.
3helpful
Rancilio Silvia: The steam works only for about 10 seconds
Remove the top panel and check the 3 thermostat on the machine one of them is not functioning properly, find the wire to the steam switch and trace it to the thermostat.
2helpful
2answers
Rancilio Silvia indicator light not turning off
Hi
Hi - I have a new Rancilio that I just opened today. Steam is coming but not enough water for a brew
maybe is just air in pump,try prime water on steam wand.open steam valve and press button for make espresso,keep couple seconds
Water will not come through the steam wand
I had the same problem. I took the steam wand off, and checked for steam out of the unit. It was OK, so I stuck a thin wire up through the steam wand and dislodged what look like pieces of a green washer or O-ring.
In short...the wand was plugged.
2answers
New Rancilio Silva - steamed milk not perfect
please relay on your experience realizing that you now have new steam pipe(with different holes in the end of it and different pressure)
you will need to get use to them and get maximum quality of that steam pipe.
my advice:
  1. every time hold your hand in the bottom of milk container, so that you will prevent overheating which often gives the result you mentioned.
  2. every time you use cold milk.
Top Rancilio Coffee Makers & Espresso Machines Experts
Sulejman Sulejmani
Sulejman Sulejmani
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
