SOURCE: delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
SOURCE: I have a kitchen faucet by hansgrohe, 06801860.
your sprayer ''picks up''it's supply from the flow to your faucet.spray heads wear out & are not repairable.replacement hose & sprayer assembly can be found at home improvement stores.if you can see the other end of the hose where it attaches to the faucet,it's not too hard to replace.you don't have to turn off the water at the meter.
SOURCE: i have a ladylux kitchen faucet and the
Call Grohe customer service...they will send you a new one for free.
SOURCE: brand new faucet, on central aerator setting (not
Aerator ,sounds like it is not on right ,maybe cross threaded,or just not tight
SOURCE: We have a fancy single
does the faucet have an aireator on the end of spigot. if so remove by turning off with pliers, and see if it is blocking the water. if it is, clean aireator and replace if necessary.
