The battery is almost out of power. Change the battery now. If the message reappears after the battery has been replaced, remove the battery again, press any meter button, then reinsert the battery.
https://www.accu-chek.com.au/meter-systems/performa/support-error-screens
SOURCE: Cannot perform set-up for Accu-Chek Performa
Hi, yes sorry but you will need to purchase new strips.
The E-1 error usually indicates that the test strip is damaged or improperly inserted. Try removing the test strip and replacing it. Try a different test strip. Open a new box of test strips and try using one from the new box.
I hope this helps. You can find the manual for the Accu-Chek Performa on the product page: https://www.accu-chek.com.au/meter-systems/performa . The direct link to the manual is currently https://www.accu-chek.com.au/download/file/fid/16491 . The error messages and trouble-shooting are to the right-hand side of the page. You will need to scroll a bit.
SOURCE: how can I change time and date on my Accu-chek performa which shows E-5 code exp
This should help:
https://www.northernhealth.ca/Portals/0/Lab/Accu-Chek%20Performa%20meter%20operator's%20manual.pdf
Best of luck.
