When its not using so many months,mechanical jam may occured, in this condition its draws more power when its switched on, fuse may blow off, check primary power section in power supply board, replace the fuse with same rating then try it...best of luck...OLD IS GOLD..
Generally drives can be left sitting for a year or more without problems but if it was bumped or jarred hard enough the heads may not be releasing from the park position, otherwise clicking sounds usually mean problems with the circuit board. If you give it a visual inspection(requires removal with a torques 5 or torques 8 bit) you can look for any signs of a burnt out circuit.
Respond back on this post if you have any further questions.
Your prob is their is a thermostatic solinode that is trigger the unit to go off--because it thinks itself as too hot and unsafe to be on--this trigger was defective or damaged by disuse and/or fatigue------give it a shake-- better yet, when cool and unplugged-vacuum or blow out with compressed air-with out disturbing integrity of workmanship on device--if that no worky--time for new one---thermostatic element is dirty, device being of differing Mghz than outlet, if fairly new device--amperage of outlet is too small for device to work properly. If it is a 240 volt or a 120 volt device and your attempiting to use the wrong voltage outlet--STOP USING THE DEVICE
remove the cartridge and set it on an alcohol-soaked paper towel in the kitchen sink for about 15 minutes. If the towel has not begun to draw ink out, then tap cartridge firmly against your other hand which is holding the towel. if still none, then try heating the alcohol to about 150 degrees and repeat. if still nothing, then ink is either spent or cartridge head is dried up. take it to cartridge world (or similar outlet store) and they can get a cheap replacement.
