F14
Looks like a keypad problem.
First remove power for 10 minutes or so and then give it a try. This may reset the board.
If this does nothing.
Disconnect the unit from power, unplug the keypad at the control board and clean the connectors then reconnect it and give it a try.
Use electronics cleaner or isopropyl alcohol and a tooth brush to clean them. Just make sure all the solvent has evaporated before reconnecting.
If the ribbon cable is the type where just the insulation is removed (no connector) the contacts can be cleaned with a pencil eraser. Do not use an ink eraser as iit is too abrasive.
Check it with a meter as shown in the tech sheet to confirm it is shot.
If it is OK then the problem is probably on the control board itself.
__________________
Here is the link to the pdf test sheet mentioned above.
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316904001.pdf
SOURCE: maytag range shows fault code F14
You have a problem with your oven temp. sensor. Remove it and check it at room temp. It should meter out at 1 to 1.1K ohms. If it doesn't replace it.
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Computer is cooked. Sorry to tell you.
I am a factory servicer for Electrolux / Frigidaire
I replace tons of those clock controls. They shouldn't be $160 though
Any questions about these stoves send me and email.
I will be glad to help you out.
Thanks
SOURCE: Oven Failure Code F1
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
to fix your F1 error
92028 RELAY PCB, 105 C
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
SOURCE: F14 error message
First change the fuse. Then if it still isn't functioning properly, you may have to replace the lamp, in which case you should contact a specialist. Details can be found in the Instructions Manual.
Go here:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
and enter EB270 and click the Go button.
Then download the PDF file of the manual in English (EN)
Hope this helps :)
Chris (ziraffa)
ps Someone else on Fixya claims to have fixed the F14 problem by changing the PCB Board, whatever that is.. but there was no further rating or feedback given. That's all I have.. Good Luck!
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
