Hmm, never heard about such problems
This sounds like a problem either with your internet/network connection or Netflix. i would recommend a few steps to isolate where the problem is:
Step 1. Use another device, e.g. tablet, pc or laptop on the same network as your Blueray device/WII and see if you can connect to Netflix.
** If you cannot connect to Netflix, go to step 2.
** If you can connect, Netflix is fine, the issue is with the connection between your router/modem and the Bluray/WII console. Go to step 2.
Step 2. Take your laptop/ tablet and connect to another network, a friends or neighbors, or a hotspot from your phone. Then try to connect to Netflix.
** If you are able to connect and watch Netflix, the issue is with your network. Go to step 3
If you are unable to connect to Netflix, you may have a problem with your account. Contact Netflix support, who are normally very good at trouble shooting the problem.
Step 3.
** On the Bluray and Wii, disconnect from the network and forget this network.
** Next power off your modem and router, wait 10 minutes and power them back up again, modem first, then the router.
** Once all the right light are steady on both the modem and router, try to connect either the Bluray or Wii to the network and see if you can get Netflix to work. If yes, you are in luck! If no, you may need help from an internet professional or the 1-800 support line of your router manufacturer.
Hope that helps.
SOURCE: 43H70 Blue Convergence out of line and will not line back up
If the blue colors will not line up, and the blue appears to sag inward from one or more sides, then you can bet that one of your convergence IC's has either cracked loose or burned out. The IC should be resoldered or replaced and the convergence realigned by someone experienced with projection TV convergence circuits.
SOURCE: Letter box picture when viewing blue ray discs on Sony BR player
All blu-ray movies are in Widescreen format. So your tv converts the picture to make it look like letterbox. There will be some movies that will have those little black bars at the bottom. There will be some movies that don't. There is nothing to worry about it is normall.
Hope this helps
SOURCE: HDD/DVD Model RH265 : worked perfectly for 14
Sounds like the hard disk might be full. How many recordings have you got on the machine? You say it won't allow you to delete "data". Have you protected the recordings?
SOURCE: unstable at start up
I assume you have a wireless or Ethernet connection for your BDP1600? It may not be working and the first thing your player needs to do is get a firmware update and this won't happen if you do not have an Internet connection. If you do have an Internet connection, look to see if there is some sort of "software update" button somewhere within the tv-based menu system.
