SOURCE: Mio p550 wireless N security connectivity problem
Had the same issue with my Mio P550's using an Airlink680W Wireless N Router and security mode WPA-PSK, TKIP & Password. I had to disable "Block WAN Ping" on the firewall and life is good.
BSL
SOURCE: flashing wifi symbol on netgear wireless router. iphone help
Hi
I will try to help you out with this....
Might be you tried to cinnect with the network many time thats why its keep on disconnecting,
you can delecte all the netwoks that you have in you 3G Iphone and try to connect fresh, if its still give you the same error then you need to change the channel on the router if still it wont connect I suggest you to change tehw ireless settings on you router and reconnect all the computer and you Iphone again with the new network...
Steps are below before you change any settings on teh router i would like to inform you that you will loss your wireless connection till you reconfigure and reconnect you computer with the new network again........
open the internet explorer on your wired computer
type in 192.168.1.1or you can type http://routerlogin.com
, it will prompt you for user name and password, the user name will be 'admin' and password will be 'password', make sure you type it in small case
click on the wireless settings under the heading of setup
check out another screen shot below :
a. Change Name SSID : name of your network that you want to have
b. CHANNEL : Change to 11 and if uts 11 change it to 06
c. Mode : change to G&b
d. Sceurity : Select WEP
e. Key1 ; type any 10 digit number or you can type 1020304050, as mention above as the password for your wireless network
you will able to see your wireless network name on your computer, simply select it and it will prompt you for password that will be your 10 digit number you punch in Key1
connect with it and you are ready to go with your wired and wireless connection
I hope above mention will resolve your concern.....
Thanks
Harmeet :)
SOURCE: I want to connect my iPhone 3G to my home wireless
The security type on the router is WEP.
In this case you will need to use the key 1. that will be the network key for your wireless network.
Check just next to the wireless security tab , you will see wireless MAC filter. It must be disabled. If it is Enabled then disable it and save the settings.
When you try to connect using the WEP key 1 , do you get any error message ?
If you get any error then try $ sign and wep key1.
Click Here for more info
SOURCE: I am not able to connect my iphone to my home wifi
No, just like when you set up a wireless connection for the first time with a home network, you need to input the network key. As long as you have the key handy, it should work!! For example, when I connect my iPhone to home network, I see my network name "553c" and I "touch" that and it asks what kind of security it has (unless this has changed, my iPhone is 1st generation) so I pick WEP (you will pick WPA of course : ) )and then it prompts for the network key. Hope this helps!!
SOURCE: Re: IPhone doesn't connect with wifi automatically - password not recoginized HELP!!!
Yep, I had the same problem with my iPhone as well (32GB 3GS).
Had the signal NO problem for about a week then POOF it was gone. WTF?
Prowled the boards looking for a solution.
Tried resetting the phone, resetting the Wi-Fi, switching airplane mode on and off, forgetting the network, etc.
HERE'S YOUR SOLUTION :
Go unplug your wireless router's power cord.
Wait 30 seconds.
Plug it back in.
Your iPhone will reconnect, and you'll be back in business.
Jack
