Computers & Internet Logo
lurdes melo Posted on Oct 08, 2018
I need to download the drivers for my roxio 2861 usb
1 Related Answer
Anonymous
  • 4 Answers
  • Posted on Jul 22, 2010
SOURCE: video choppy when capturing. Using video to
I will need more info on your PC setup to be able to help you.
I can not download my roxio usb 2861 on my computer i can not instaled my roxio easy VHS to DVD bicause the USB not instaled can you help me ty
Hi, you need to install USB video capture device before using the software, please check the following link to find driver according to your operating system:
Corel KBSearch Articles
Also the following article can provide you more information:
Installing Easy Vhs To Dvd On Vista Home Premium 32 Sp1
1helpful
I have had Roxio Creator 2011 for 3 years and have been able to copy many of my vinyl Lp's onto the system. However I have not used it for about 8 months and when I tried to 'record' some more LP's I...
If you didn't install the driver of the USB record player, it won't pick up all but the basic functions of the unit. try upgrading the driver of the LP usb player.
I am running Vista and trying to istall easy vhs to dvd into my computor It has accepted all but says usb 2861 device has failed and to check with you to solve this problem Bruce e mail
If you are using more than one USB devices at a time - especially on the same USB physical port (through a hub, say), then there may be insufficient power for the device. If you unplug the device and plug it back in again (preferably on a physical port to itself), if the device is working ok, windows should pick it up and search/ask you for appropriate drivers or manufacturers disk.
Btw give the device at least 10 seconds after unplugging it before plugging it back in again.
Allan
My laptop is ibm thinkpad 2861. my internet cannot run because my driver is no longer working
You need ti install the LAN driver again, If you have not got it then
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model computer, Use this link :-
http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download
2answers
Roxio media creator 7
goto this site and reinstall it for free http://www.brothersoft.com/downloads/roxio-easy-media-creator-7.html or goto cnet.com for the driver.
2answers
Driver
Download and install adobe reader for manual, if needed
use Get Adobe Reader button on this page
http://www.adobe.com
Manual link (two choose based on directions)
http://www.bushnell.com/customer_service/manuals/binoculars.cfm
There may be no driver required for vista for the USB access to the camera.
However one of the manuals indicate Roxio may provide updates for photosuite. No assurances there are that either link to provided software is applicable to your version however generally updaters will not update the incorrect software. There is also no notation that these are or are not Vista Compatible.
This Vista support link may help
http://kb.roxio.com/content/kb/General%20Information/000004GN
This Update is PhotoSuite Version Specific, you will need to find the version of PhotoSuite installed on your system before selecting the update.
To find the version of PhotoSuite that you have installed first open PhotoSuite and then Go To "Help" and then to "About Roxio PhotoSuite", once the About box opens you will find the version at the bottom center.
If you have version 5.1.2529.0 or higher this update is not needed.
Updates the PhotoSuite components of Easy CD & DVD Creator 6 PhotoSuite version 5.0.1366.0 only.
Note: The latest Easy CD & DVD Creator Engine update should have already been installed.
(This update will take 5 to 20 minutes to install, there is no progress bar, so you should not interrupt it.)
Download
Updates the PhotoSuite components of Easy CD & DVD Creator 6 PhotoSuite version 5.0.1419.0 only.
Download
Update PhotoSuite 7 Platinum to 7.0.430.0 (English Only)
Important Note:
This updater is intended only for the stand alone version of Roxio PhotoSuite 7 Platinum. If your version of PhotoSuite 7 was included with Easy Media Creator 7 then please (use those listed above) for the correct updater.
Download
Driver
Manual link (two but these appear to be the same)
However the manuals indicate Roxio may provide updates for photosuite. No assurances there are that either link to provided software is applicable to your version however generally updaters will not update the incorrect software. There is also no notation that these are or are not Vista Compatible.
Download
Download
Important Note:
Download
Top Roxio Computers & Internet Experts
 Grubhead
Grubhead
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
