Where did you buy the boards? Shop Jimmy is the only reputable seller of television parts. This Tip I wrote explains the issues. Hopefully, our Television Expert Larry will be along soon.
Hisense 58R6E Parts ' ShopJimmy
shopjimmy.comhttps://www.shopjimmy.com
The Online Leader In TV Repair And Replacement Parts. Check Out Our Huge Inventory Today! 180 Day Warranty. TV Repair Made Easy. Repair Kits Available. Servicing All TV Brands. Highlights: Newsletter Available, Multiple Payment Options Available.
TV PartsTV Boards, Cables, Lamps, Remotes, Speakers, Stands, Tools, And More!
TV ComponentsScrews, Capacitors, Diodes, Fuses, ICs, Resistors & More TV Components
TV Stands & MountsWe Have A Variety Of Universal Stands & Mounts For Every TV Set!
I agree with you Gerald, changing the strips involves removing the panel and on a set of this size that can be an issue unless someone has the proper handling equipment and uses static precautions but taking it for repair will run more than it's worth as most places charge from $2 to $2.50 an inch for labor, total cost would be about 2/3 the cost of a new set but if a person can do it themselves the strips only run about $75.
No it will not be the tcon board clicking and if you see the logo that board is working. Your going to need to get some voltage readings from the power board and see if it's working ok for starters. Next would be unplug the backlight connector and see if the sound goes away, if it does you have bad backlights and I think this will be the issue
Hisense actually made several boards that are used by many manufacturers. This may just be a case of the only hisense boards still being available are ones they made for samsung.
