Help
SOURCE: Sharp Microwave Oven
Quite often this is due to grease or food particles stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced.
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
If you need further assistance, please feel free to contact me directly through the links at our site: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Sharp cash register XE-A41s
Hi. turn key to OPX/Z mode. Press the receipt button. Turn back to REG mode. Now when you want to issue a receipt, press the receipt button.
Mark
SOURCE: Re: Sharp carousel microwave oven minute display light out
Hello there
To replace the light you will first have to remove the outer shell.
To do this
(1). Remove all of the screws on the back of the microwave that hold on the shell
(2) Remove the screws that are on the bottom.
(3) now the shell should slide off towards the back of the microvave.
Note : this may take a little bit of pressure to get it off ok?
(4) Once the cover is off look towards the fromt of the microwave and
you will see the bulb. now just replace the bulb and reinsert the cover and the screws and you are all done ok? pretty easy ha/
best regards michael
SOURCE: I bought Nokia 6303 classic in Brighton, Tesco,
Try 1234
or 12345
Let me know how you go as they are default codes
SOURCE: instructions for Sharp R953 900wt jet convection grill microwave
i have need instruction book how i can use sharp micro wave oven r953
