The metal pin & silicone "O" ring just fell out of the lid of my Living Well 8qt pressure cooker. It will go back in several ways, but I cannot find information on which is the CORRECT way.
SOURCE: Rival Rice cooker steamer model 4356
Lydia, there are notches on the side of the metal liner. Line 1 is for one scoop of rice filled with water to the line marked 1. The scooper that comes with it holds 2/3 cup of rice. There are smaller notches above and below each numbered notch. That's to make rice looser or stickier, depending on your preference.
Hope that helps.
SOURCE: lid of Russell Hobbs pressure cooker is broken
Try going to MarBeck.com they are a great source for small appliace parts.
http://www.marbeck.com
SOURCE: I need a new cooking
Replacement parts for the Wolfgang Puck pressure cookers are difficult to find and I just received an e-mail back from an earlier inquiry to the the company advising that parts are available here:
http://www.wpcookware.com/categories.asp?cat=29
Not sure if your model is the BPCR0007 but cooking pots are available on-line; you may want to confirm compatibilty with their Customer Service at 1-800-275-8273 or make an inquiry via their webform:
http://www.wpcookware.com/contact.asp
SOURCE: Looking for place to order replacement Seal Ring
Replacement parts for the Wolfgang Puck pressure cookers are available here:
If you do not see the part you require or are unsure about the model number; suggest you contact their Customer Service at 1-800-275-8273 or via their webform at:
Sorry someone has not responded sonner.
SOURCE: How can I get a Safety Release Valve?
Check with the company that made your pressure cooker.
