Televison & Video Logo
Anonymous Posted on Oct 08, 2018
Sylvania SDVD1048 10-Inch Portable DVD Player has sound but no picture
Try changing input or source
5 Related Answers
Anonymous
  • 1139 Answers
  • Posted on Oct 09, 2007
SOURCE: Phillip PET710 Portable DVD Player
The back light of the monitor might be defective. or the drive signal might not be getting to the screen you will need a schematic, multimeter, and an oscilloscope to troubleshoot this issue. This is how you will have to go about this using the schematic locate the screen test points measure the voltages with the multimeter and look at the signals with the oscilloscope. this will lead to you finding the exact problem.
Anonymous
  • 291 Answers
  • Posted on Nov 07, 2008
SOURCE: Panasonic DVD-LS855 wont play to LCD TV
Did you turn on the input of the tv to receive 'external' input.? Did you plug the DVD into the right input?
Anonymous
  • 320 Answers
  • Posted on Mar 06, 2009
SOURCE: I have sound but no picture on my portable DVD player.
yes it can be fixed.replace the capacitor c564 and c513 on the main circuit board to bring the picture back as this capacitors gets over heated and cause this problem.
Anonymous
  • 814 Answers
  • Posted on May 29, 2009
SOURCE: I have sound but no picture, can you help
Please give more information, on how you found the problem. Have you tried the video output connected to another monitor to see if the video processor circuits are still functional. You can do this by using cables to the video output of the dvd player to the input of your television. Usually Three wire connections. The yellow connector is for the video and the red and white connectors are for the audio. Make these connections and use your television on a alternative signal source input. This is usually a function button on the television or the remote control. The function is usually labeled input. You can find the correct set-up information with pictures in the owners manuals of the products. If after testing the video ouput from the dvd player. You find that you do have output, then you may have a connection problem between the main board and the LCD screen. These connectors are usually ribbon cables and are a yellow or golden color. They are connected by a clamping connector. The connector is usually released by using a small screw driver to release the clamping device. You can check the connector and see if it looks like it still working. If the connector looks crimped,torn or bent badly it may need replacement. If they look ok , then you may want to use some contact cleaner to clean the connection points and the connector. You can do this by spraying a small amount of contact cleaner on a cotton swab. Take the swab and wipe the connector, cleaning the connection points and then use a small brush with a small amount of contact cleaner to clean the connector. You can also use a can of compressed air to blow all dust and debris from the connector and the circuit board. Make sure to clean all areas of the board as dust and dirt act as a heat blanket and cause overheating problems on the ciricuit board. If all of this seems over your head. Have a friend help you. Or take it to a repair shop for evaluation. There are many helpful videos on you tube that can show you how to do the disassembly and cleaning of the player . Look under cleaning and repairing portable dvd players. If you have a vidoe processor failure, then it may not be repairable. The expense may be more than the cost of just replacing the dvd player. I hope this information helps you with your problem.
Anonymous
  • 814 Answers
  • Posted on May 31, 2009
SOURCE: my portable dvd player has sound but no picture on the screen. pl
If you still have use of the on screen menu functions, you can try using the restore to factory setting option in the preferences section of the set-up menu. Press the setup button on the remote control and use the up and down arrows to find and highlight the preferences section, press ok to enter the sub-menu.In the sub-menu use the up and down arrows to find and highlight the default option. Press ok. This will reset the dvd player to the factory settings. If you do not have the use of the on screen menu, you can use the a/v outputs to a external monitor or television to perform the abouve procedure to try to restore the dvd player to normal operation. If all this fails you can call Phillips customer support at this telephone number. 1-888-744-5477 They will be able to help you, either solve your problem or get the dvd player serviced.I hope this information helps you with your problem.
1helpful
2answers
2answers
Best Buy says the Sylvania SDVD1332 is unrepairable. Purchased Sept 28 2020. I need a replacement
This is a low-end DVD made in China as Larry (Anonymous) says.
90 day warranty on it was the first clue not to buy. Just buy another, a better make If you are using it in a car, you need one MADE for a car.
Sylvania 13.3-Inch Swivel Screen Portable DVD Player ...
https://www.amazon.com > Sylvania-13-3-Inch-Swivel-...
Sylvania 13.3-Inch Swivel Screen Portable DVD Player (SDVD1332) with USB/SD Card Reader · Technical Details · Additional Information · Warranty & Support · Feedback.
Item Weight: ‎4.18 pounds
Batteries: ‎1 Lithium Polymer batteries required. ...
Product Dimensions: ‎19 x 3.25 x 12.25 inches Rating: 4.2 · ‎2,327 reviews
SYLVANIA SDVD1332 - Hyper Microsystems
https://hypermicro.com > sylvania-13-3-portable-dvd-p...
Sylvania SDVD1332 13.3-Inch Swivel Screen Portable DVD Player with USB/SD Card Reader ... Mfg Part#: SDVD1332; Manufacturer: SYLVANIA; Warranty: 90 Days ...
Sylvania SDVD1332 13" Portable DVD Player - B&H
https://www.bhphotovideo.com > 1010462-REG > sylv...
Buy Sylvania SDVD1332 13" Portable DVD Player featuring 13.3" TFT LCD Screen, ... Audio/Video Cable; Remote Control with Battery; Limited 90-Day Warranty.
Rating: 4.5 · ‎29 reviews
Sylvania 13.3 Portable DVD Player Black SDVD1332 - Best Buy
https://www.bestbuy.com > ... > Portable DVD Players
geek squad logo. Protect your portable DVD player. Warranty Protection Plans. Most popular protection plan for your product. 2-Year Accidental Geek Squad ...
Rating: 4.3 · ‎1,027 reviews · ‎US$149.99 · ‎In stock
Sylvania SDVD1332 SDVD7040B SDVD7046 Remote ... - eBay
https://www.ebay.com > ... > Remote Controls
This is a genuine Sylvania remote, fully tested and sanitized. ... loading Sylvania SDVD1332 SDVD7040B SDVD7046 Remote Control Lifetime Warranty and Free S.
Type: Remote Control
Condition: Seller refurbished
I have a Sylvania 32 inch DVD not reading the DVDs what's wrong???
How To Fix a Portable DVD Player That Is Not Reading or ...
? 17:12
https://www.youtube.com/watch?v=ucNedtR256g
Jan 18, 2015 - Uploaded by orly lando argallon
How To Fix a Portable DVD Player That Is Not Reading or Loading Discs. ... 2:32. How To Clean A DVD ...Missing: inch
Amazon.com: Sylvania SDVD9805/SDVD9805-C 9-Inch ...
www.amazon.com/Sylvania-SDVD9805-SDVD9805...
Amazon.com, Inc.
Rating: 2.9 - ‎916 reviews
Sylvania SDVD9805/SDVD9805-C 9-Inch Twin Dual Screen DVD Player. Sorry .... 5.0 out of 5 stars32+ hour car trip ... One remote does not work on both, only works for the one it came with. .... Garbage, 3 months in the first of the two DVD players stoppedreading the DVD's so we only used the one and now 5 months in the ...
Sylvania SDVD9805/SDVD9805-C 9-Inch Twin Dual Screen ...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Sylvania SDVD9805/SDVD9805-C 9-Inch Twin Dual Screen DVD Player at Amazon.com. Read honest and ...
My 9" Coby V.ZON TFDVD9109 Swivel Widescreen Portable DVD Player won't charge but will turn on and stay on as long as I have a charger hooked up what can I do about that
Coby TFDVD9109 9-Inch Widescreen TFT Portable DVD ...
www.amazon.com/Coby-TFDVD9109-9...Widescreen...
Amazon.com, Inc.
Rating: 3.6 - ‎52 reviews
Sylvania 9-Inch Swivel Screen Portable DVD/CD/MP3 Player with 5 Hour ... has never been easier with the Coby TFDVD9109 9" Portable DVD Player. .... The DVD player finally stopped working, won't load discs anymore, gives error message. I had a ... I'm currently doing my research for a new a player but likely will end up ...
Coby TFDVD7009 7-Inch Portable DVD/CD/MP3 Player, Black
www.amazon.com/Coby-TFDVD7009...Portable-Play...
Amazon.com, Inc.
Rating: 3.7 - ‎240 reviews
Ac Power Adapter Cord for Coby Dvd Players Tfdvd1029 Tfdvd7009 .... So in my case 5 zone is needed and it worked well. ... There is inconvenience in charging. ... that once you unplug the battery the connection is so cheap that it won't reconnect. .... Sylvania 9-Inch Swivel Screen Portable DVD/CD/MP3 Player with 5 Hour ...Missing: tfdvd9109
Coby Electronics TF-DVD7006 7-Inch Widescreen TFT ...
www.amazon.com/Coby...DVD7006-Widescreen-Port...
Amazon
I have audio but not picture. I have cleaned the lens with alcohol. Any other ideas or is this trash?
Amazon.com: Gpx PDL805 8.5 Inch Portable DVD Player ...
www.amazon.com/Gpx-PDL805...Portable-Player/.../...
Amazon.com, Inc.
Rating: 2.5 - ‎14 reviews
I got this GPX brand portable dvd player a couple days ago and am so far satisfied. It does everything I ... The picture is pretty sharp, and the sound is decent. And I didn't... Not Happy with my GPX8.5 portable dvd player PDL805. By Nanarozi ...
Gpx PDL805 8.5 Inch Portable DVD Player > Customer ...
Amazon.com, Inc.I got this GPX brand portable dvd player a couple days ago and am so far satisfied. It does everything I ... There is no menu button on the player itself! If you don't have ...The picture is pretty sharp, and the sound is decent. And I didn't expect ...
gpx dvd player sound Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on gpx dvd player sound related issues.... Question about PDL805 Portable DVD Player ... lets I have a GPX PD708BPortable DVD player that has picture but no sound, this is actually my second ...
GPX PDL805 Portable DVD Player Pd808b - Questions - Fixya
www.fixya.com > ... > GPX > GPX PDL805 Portable DVD Player
Video Does not work on New Magnavox TV
Hi, it sounds like your problem is that you've selected the wrong "video input" for your DVD player. Your new television most likely has at least 3-4 (sometimes 6-7) different inputs for video. With your DVD player connected and turned on, press the "Source" button on your TV to cycle through the different inputs. Be sure to wait 2-4 seconds between selections to give your TV enough time to switch inputs. If your DVD player has "color coded" output cables, it's most likely a "component" video connection. See if one of your video inputs on the TV is called "Component". Some other video types are Video, DTV, HDMI, SVideo, Component, Composite, RGB, PC Input, etc...
INSIGNIA PORTABLE DVD
Use the A/V outs to the composite cable and connect to your Westinghouse A/V jacks.
On the Insignia player, press the Source button until you see A/V OUT on the insignia players screen.
Set your Westinghouse to the A/V input port you have connected the Insignia player to and VIOLA...you should have picture and sound.
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
