I'm writing from the Albuquerque Biopark in Albuquerque, NM. We have 2 hoists and one has grease coming down the chain. Is this normal? What should I do about it? Clean it? Add more grease? Thank you, Debra
SOURCE: 4 wheel drive won't engage on hte hoist
I would put it in 4x4 before or as you bring it in the bay to get it to lock in 4x4.All the wheels need to role at the same time in order for it to go into 4x4.
SOURCE: where do I locate the oil filter? do I need a
The oil filter is located on the driver side of the engine, just below the intake manifold, on the side of the engine block. You will need to get it from the bottom of the car, so a "hoist" or lift will make it easier than jacking it up and sliding under the car, which can also be dangerous.
This should be fairly easy to replace otherwise.
Just be sure to get a new ring gasket for the engines very large drain plug if you are changing the oil.
SOURCE: How do I hoist or lift an old 2001 Mercury Sable
ENGINE AND TRANSMISSION HAS TO BE SUPPORTED ON THE BOTTOM BY A POWER TRAIN LIFT. THE ENTIRE CAR BODY HAS TO BE RAISED BY A LIFT UP AWAY FROM THE POWER TRAIN WHICH IS SUPPORTED UNDER THE BOTTOM WITH A SPECIAL POWER TRAIN LIFT OR TABLE.
To install:
