It might be the hardware try consult to it specialist there might be some problem inside your laptop
REVISED LATER, FOR FULL ANSWWER
NO PC no OS stated, so answers are generic
ok, no facts no answers EXACT POSSIBLE.
A BAD PAD (A HARDWARE DEVICE THAT REMOVES)
bad cables TO IT AND MOBO.
bad drivers. 3 possible causes.
GO GET EM;TIGER
http://www.packardbell.com/pb/en/GB/content/download
SOURCE: NEED TO DOWNLOAD CD ROM DRIVER FOR MY PACKARD BELL IPOWER 5264 LAPTOP
Hey there SHAMESTAR, Not an easy find, but here is the location:
http://support.packardbell.com/global/item/index.php?m=home&pn=P730012001
If the link doesn't work, just copy and paste. Good Luck. Let me know if you have any problems!
SOURCE: PACKARD BELL EASYNOTE MV35-202 keyboard and mouse pad won't work
The first thing to do is my computer properties see if your keyboard and mouse are showing in there
If they are you need to update the drivers.
If they are not showing then I would suggest going to control panel and add new hardware installing that way
Try using a standard mouse instead of usb
If you cannot get on try restarting in safemode to correct your problem.
Or if you have a cd that came with the mouse and keyboard reinstall it.
Let me know if this helped also did you reinstall the same version of windows
SOURCE: dell inspiron I6400 touch pad is not working
Unless there is not a hardware switch and the only manufacturer that I know of that did that was Compaq/HP about 5 or so years ago. Typically there are no drivers to be installed for a mouse (touch pad) as a generic set is in the driver library of the operating system. 9 times out of 10 it is a hardware failure. With that being said, if it has warranty send it in, if it does not, (although it may just be a loose connection or the touch pad itself) most repair shops are going to run anywhere from 150 - 300 dollars just to crack it open. Best option is to get a small USB mouse, unless you just really want the touch pad.
SOURCE: vertical scrolling not working
you can activate this by
1. going to the control panel on your vista machine, make sure you are in classic view
(2) double click the mouse icon.
(3) From here you will select the "Device Settings" tab,
(4) make sure your Synaptic Pointing device is highlighted and then click the settings button located directly below the "port" column, this will bring up properties for this device.
(5) With all categories in the left hand column collapsed, select "Virtual Scrolling" here is where you will find the box that needs to be checked to enable vertical and/or horizontal scrolling.
(6) make sure the "Enable Vertical Scrolling" box is checked.
(7) don't forget to hit apply!
SOURCE: touch pad is disabled and cannot enable it
There will be a function button on the keyboard to turn it on and off, look at all the f1 f2 etc keys and look for a mousepad symbol and press fn + that button.
NO PB model stated, some laptops
NO COUNTRY STATE, TO USA FORUM THAT HAS NO PB SALES SINCE 2000.
your pad is bad or the unstateed OS has a corrupted driver for the pad
or kids play with the setting and messed them up.
the advanced setting is an option, no found on many laptops and is grayed out.
if all settings act wrong, the driver is bad.
mostly. but cables can fall off the pad inside.
no PB in usa, AND WE ARE THERE.
PB LEFT HERE 1999, SEE WIKI ON TOPIC.
