SOURCE: Zanussi err problem
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
SOURCE: My Zanussi Dishwasher ZDF231 is not draining
Check the drain hose isn't kinked or blocked. Check the filter in the inside bottom of the isn't clogged.
SOURCE: While dishwasher is washing, the motor is making a
You will have to open up the panel to check exactly where the sound comes from. It can come from the motor itself or the moving parts. Some parts are being moved by water and cleaning the insides and the filter sometimes removes the noise.
SOURCE: Hi, my zanussi zdf221 dishwasher wont work, it
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified
