SOURCE: Need owners manual for Nesco Gardenmaster Food Dehydrator FD-1000
Here is the User manual you require mate :
http://www.nesco.com/files/pdf/food_dehydrator.pdf
Lemme know if this resolves your query :-)
SOURCE: I have only had my
There is a recall of some of these. Check it out here:
http://www.cpsc.gov/cpscpub/prerel/prhtml11/11104.html
SOURCE: Wiring Diagram for Nesco FD60 Dehydrator
There is a recall on some of these. Check it out here:
It has to do with something overheating. Maybe your unit is covered...
SOURCE: wont power up
The DC jack in the laptop is the most likely trouble, first! remove main battery and power supply from the computer, now press and hold power for 2 minutes to drain off residual voltage, next plug everything back in and attempt startup, if no change! computer must be dismantled down to the motherboard to address.
SOURCE: Where is the crofton food dehydrator power switch?
my crofton food dehydrator just stopped working after the 3rd use. I bought it from Aldi and since I lost the receipt they said they will refund me if I mail the whole thing to them which means I will end up paying more than what they will refund me. Any idea of how I can get repaired. Mine had no power switch and the manual doesn't state what problems might occur.
