Alcatel Newbridge MainStreet 3612 Multiplexer Logo
Posted on Aug 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the pinout for the serial cable? RJ45 to DB9
fibrewire
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 25, 2009
fibrewire
Contributor
Level 1:
Answers
Questions
0
Helped
6580
Points
5
I need the pinout for the serial cable? RJ45 to - f211598.png This is for a newbridge or alcatel 3624 mainstreet channelbank - do not use the modem side, only use the terminal side - all is needed is Rx, Tx, and ground - if looking from the "window" side of rj45 connector, or pins-side up on rj45 socket.
Anonymous
Level 2:
  • Expert 164 Answers
  • Posted on Aug 03, 2009
Anonymous
Expert
Level 2:
Answers
164
Questions
Helped
55589
Points
475
Http://www.commdevices.com/pdf/standard-rj45-db9-pinout.pdf
Dont forget to rate the advice.
http://www.aa1consulting.com
1 Related Answer
Anonymous
  • Posted on Jun 10, 2010
SOURCE: Need 3612 mainstreet j8 pinout configurations
DB9 -----------------------------------> RJ45 1 ---------------------------------------> 8 2 ---------------------------------------> 4 3 ---------------------------------------> 3 4 ---------------------------------------> 7 5 ---------------------------------------> 5 6 ---------------------------------------> 6 7 ---------------------------------------> 1 8 ---------------------------------------> 2 9 ---------------------------------------> NC
If not work, invert the RJ45 connector
2helpful
3answers
How to you connect to the serial port to a DSR2010?
the 2010 is a legacy KVM DSR, and you might not have the same features that are present on the 8035 model. the settings to connect to the 2010 with a NullModem cable are 9600, 8, none, 1, none (same as Cisco settings).
The 8035 comes with a special adaptor which is DB9 to RJ45 and it comes in the box.
I hope that answers your question.
As far as console logs goes, no such thing on the DSR line.
2helpful
How do you connect to a terminal with avocent dsr8035
You should have a DB9 to RJ45 converter in the box. This converter is used to change from DB9 serial to RJ45, which is the port on the DSR that is used to connect to the serial console.
Should you do not have such connector, call Avocent Tech Support, they will help you to get that converter.
The NullModem Cable might also be requiered
Also remember:
9600
8
none
none
1helpful
Db9 rj45 pinout
Here is the standard pinout for a console port on a router to seriel port for computers
Need driver for CISCO DB9 TO RJ45 6FT CABLE 72-3383-0 for my notebook
If I am understanding correctly, you are using a serial to ethernet cable. The serial cable plugs into your laptop and the ethernet end plugs into the CONSOLE port on the Cisco.
From here you use a terminal emulation program like "Hyperterminal" to connect via the serial port. As long as your serial port is installed, no other drivers are necessary.
3helpful
Need 3612 mainstreet J8 pinout configurations DB9 to RJ45
1helpful
2answers
I need MSR206 data cable diagram RS232 conection
this doesnt solve the guys problem. the cord he has is cat 5 cable with only four wires in it, the adaptor is made only by the company he got the msr206 from. best thing to do is to contact www.tyner.com and ask for a replacement adaptor.
1helpful
2answers
I need MSR206 cable data
you can buy the usb data cable for the msr206 at Diij Electronics, look under the accessories for the magnetic card writer section. there website address is http://diij.com
1helpful
Rj45 male to db9 male cable for ups
If you have a BackUPS CS, you are probably either using it with the USB cable that is supplied or with the 940-0128A supplied by APC, which permits running the UPS in dumb mode. By building your own cable, you can now run the BackUPS CS models (and perhaps also the ES models) using smart signalling and have all the same information that is available as running it in USB mode.
The jack in the UPS may be easily use a 8 pin RJ45 connector. It is easy to construct the cable by cutting off one end of a standard RJ45-8 ethernet cable and wiring the other end (three wires) into a standard DB9F female serial port connector.
PC Signal PC pin UPS Pin UPS signal RxD 2 2 TxD TxD 3 8 RxD GND 5 7 Ground FG Shield 4 Frame Ground Though these UPSes are USB UPSes, APC supplies a serial cable (typically with a green DB9 F connector) that has 940-0128A stamped into one side of the plastic serial port connector.
Here is suggested scheme of original 940-0128A cable
APC Part# - 940-0128A computer --------- Inside the Connector--------- UPS DB9-F | | RJ45 pin - signal | | Pin - Color | | 4 DSR ->|---+ | | | diode resistor | 6 DTR ->|---+---->|----///---o kill power | 8 Orange | | 1 DCD <-|----+ | | | | 2 RxD <-|----+----------------+--o low battery| 3 Brown | | | 7 RTS ->|----------+--///--+ | | | | | +--///--+ | | | | 8 RI <-|----+----------------+--o on battery | 2 Black | | | 9 CTS <-|----+ | | signal | 5 GND --|-----------------------o ground | 7 Red | | 3 TxD | | | chassis | Chassis/GND |-----------------------o ground | 4 Black | | | Not connected | 1, 5, 6, 9, 10 --------------------------------------
NewBridge 3600 Mainstreet
Hello
The pinout is determined by the serial port you are plugged into. Are you using serial port 1 or 2. This is pinout from a standard DB9 PC serial port should get you into SP1.
Blue-8
Orange-7
Black-2
Red-3
Green-5
Yellow-4
Brown-6
White-No Connect
Write back and let me know - BAD421
Top Alcatel Computers & Internet Experts
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
