SOURCE: Goldstar MV1501W not heating or turntable, light/display does wrk
micro switch is bad .remove top vent cover 4 screws,after removing plastic vent panel you will see 1 screw above display time window,remove this screw and lift up the complete button time control panel slightly and pull towards you to remove.there are 2 connections on this panel 1 is a 12 pin connector and a 2 pin power connection remove both put control panel aside.now there are 3 micro switches where the door pins close into the oven lock,remove 2 screws that hold the micro switch housing,on the bottom of housing you will see a small clip gently pull to the right and push back to remove .there are 2 switches on bottom of it and 1 on top. the 1 on top is normally open and closes when door is shut but like mine it stayed open and resulted in (light s display but no turntable)soon as i replaced upper microswitch it runs perfect.i hope this helps .MODEL MV1501W GOLDSTAR
SOURCE: I jus brought an LG microwave oven (MODEL
E-02 on the LED display.
That usually indicates a keyboard error...not a good thing...take it back and get a new one.
SOURCE: Samsung Microwave Oven shows -SE- on the display. Why?
-SE- error means you
have a shorting membrane keypad.
Since
it's less than one year old, it would be fully covered under warranty.
I'd suggest contacting the manufacturer to get it fixed free.
You can find your
nearest Samsung-authorized service center here or call Samsung's Service Division at 800-932-3837.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: LG Microwave MH-685HD Owner's Manual
Try this website: http://www.service-manual-owner.com/lg.html You may have to email the person to get the manual?
SOURCE: no display on microwave touchpad for ge Model JKP62G
The GE JKP62G Microwave / Oven combination has an internal fuse behind the control panel for the microwave. The oven will operate but the microwave will be totally dead (no light, no clock). Turn off the breaker for the oven at the fuse box (30 Amp double breaker). In order to replace the fuse you will have to open the door to the microwave, remove the two screws (Torx) from the front control panel (located on the left edge of the control panel), wiggle the panel to the left (there are two metal tabs that stick into the metal frame of the microwave on the right of the panel) and then tilt the panel down from the top. There is a metal bracket that holds the control panel to the microwave at the bottom (don't remove it). Look towards the top of the microwave inside the area behind the control panel and you will see a 15 Amp screw in fuse. Replace the fuse and that should fix your problem.
